Fluids and Misc things I don't know - Ford Powerstroke Diesel Forum
post #1 of 6 Old 04-16-2010, 05:54 PM Thread Starter
Doc8402's Avatar
Fellas,
Once again I am in need of info and the collective knowledge here has yet to fail me.
Doing the dfuser coolant filter kit next week, whats the deal with the special stealership coolant? Anything else being run that is better....
Trans filter, should I change the pan filter? 75K on the truck and the fluid has not been changed ( I know I should have done it when I got the truck 10K ago ) W
hat filter is the small one in the front of the truck by the bumper?
What ATF? book says MERCON V so once again the stealership....
How tough is an add a leaf to install?
I am not studed yet should I tow my 5th wheel 15K+ with the tune from Eric or run stock? I am doing about 7K in a month towing this summer
I know I have more questions but a week of 15hr days has cooked my brain... Thanks in advance again for the knowledge
"People sleep peaceably in their beds at night only because rough men stand ready to do violence on their behalf. "
-- George Orwell
2006 F250, Crew Cab, FX4
MBRP 4" Exhaust, Still got the Muffler, but I'll be damned if I know where the cat went...
SCTX3
Tuned by Innovative
Auto Meter Pyro, Trans, Boost gauges
Camping Anyone???
40' Forrest River Sandpiper 355QBQ
26' Skyline Layton 228LTD (for sale)
Doc8402 is offline
post #2 of 6 Old 04-16-2010, 06:20 PM
MoyockPowerstroke's Avatar
Valvoline's Zerex G-05 is the same spec...you can read the bottle if you don't believe me...also, its my understanding they produce it for MC. Its definately much cheaper though and can be found at places like NAPA.
I wouldn't bother with the internal tranny filter until I had over 100k, but the exterrnal FT-145 I change every 15K. The Torqshift 5 only eats Mercon SP or the newly produced Mercon LV...thats it, nothing else has been guaranteed.
I would not tow with any tune that adds HP....just suck it up and put her in tow/haul mode and enjoy your stops at the refilling stations. You could maybe use a Trans Only tune, but thats it...most of the tuners wouldn't even recommend a mild tune past 8k of towing....best not to chance blowing your tranny.
Go ahead and flush your brake fluid also, you should use nearly three qts if you do it right...that mess needs flushing every two years...most forget it though. Also, flush your Power Steering fluid...you know that it supports your hydra-boosted brake master cylinder, so you want good clean power steering fluid as well. Whens the last time you flushed your coolant? If you don't have a CCV filter or have it re-routed, clean your CAC tubes.
'05 6.0L, 128k miles, Racor CCV6000 Filter, Oil Bypass Filter, Fumoto drain valves, Coolant Filter, ZooDad, HighIdleMod, BullyDog 4" TB, VXCF9 Strat, Edge Insight Gauge, Torque App, Fuel Press Gauge, Upfitters, 4" SJ lift w/Bilstein 5100's, Ride-Rite Airbags, Rough Country Dual Stabilizers, 24" Wipers, '08 Rear Diff cover, Mobil1 Syn 5W-40, 6.4L banjos, Blue Fuel Spring, SS HPOP screen, '08 Mirrors, Zerex ELC.
MoyockPowerstroke is offline
post #3 of 6 Old 04-17-2010, 07:17 AM
Slacker
Evil Eye's Avatar
Quoted: 219 Post(s)
Feedback Score: 4 reviews
Glad to see you around, Doc. The Gold coolant is the only thing that works and doesn't create cavitation problems.
Coolant bypass filter
It's a GREAT addition to the 6.0L setup to prevent oil cooler and EGR cooler failures. Simple to install and very cheap (as far as PowerStroke parts go)
Tranny Maint
Also (like said above), you should only get Mercon SP or Mercon LV for your tranny. I got mine for about $3/quart when I bought a whole case. You'll only need between 8-10 for a tranny fluid change. At this stage, don't bother with dropping the pan or worry about the in pan filter. Change it at 100k. Also, the little tranny bypass filter, I agree with Moyock to change every 15k.
Towing
Since you tow a fair amount (I do as well), ensure you are consistent with your oil changes at 5k. Since I change so frequently and have noticed NO marked improvement using synthetic oil, I simply run MotorCraft 15w40 from Wal-Mart and change EVERY 5k miles. Also, there are several tuners that have a heavy tow tune for folks like us. It adds (at most) up to 50hp and still keeps the EGT's in check even when pulling a decent grade with a load. I have run Innovative for the past 2 years when towing my 12k lb toy hauler with no issues.
Differential cover
A good number of people have opted to replace their stock rear differential cover with the upgraded aluminum finned differential cover that started in 08. They are less than $50 and can drop your diff temps by as much as 20*. Be sure to replace your diff oil with 75w140 synthetic oil if you do it. Also, it will require longer bolts since the diff cover is thicker. I just went to Lowes with one of the old bolts and got mine. Simple and less than $10.
Add-a-Leaf
I would STRONGLY suggest air bags over an add-a-leaf with the primary reason being that you can deflate your bags when you don't need the extra support. With an add-a-leaf, you can't and it is a much harsher ride. What I would also suggest is to get F350 blocks (4" versus the 2" on the F250), which will give you a bit more height when towing and won't squat your rear. I have just recently opted for the F350 blocks and don't need as much air to maintain a level trailer while towing.
PM me for ANY questions on my setup.
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is offline
post #4 of 6 Old 04-17-2010, 04:44 PM Thread Starter
Doc8402's Avatar
Just ordered the dfuser coolant kit...
When I service my trans should I drain the torque converter too? I am assuming so
-- George Orwell
SCTX3
Tuned by Innovative
Camping Anyone???
Doc8402 is offline
post #5 of 6 Old 04-17-2010, 04:59 PM
Slacker
Evil Eye's Avatar
Quoted: 219 Post(s)
No, there is no drain plug for the torque convertor. The only way to do it would be to have it flushed out and that probably isn't necessary. Drain the pan, replace the bypass filter and add 8-10 qts of Mercon SP or LV.
Shawn Carlson
Proud Navy Vet
Engine Mods:
Fluidampr
4" MBRP Exhaust
MTW Stage 1 Turbo
Exterior Mods:
Evil Eye is offline
post #6 of 6 Old 04-17-2010, 05:05 PM Thread Starter
Doc8402's Avatar
alright then well lowers the $$ on the tranny service and frees up some time too
-- George Orwell
SCTX3
Tuned by Innovative
Camping Anyone???
Doc8402 is offline
