California Exhaust Kit - Ford Powerstroke Diesel Forum
Old 04-13-2010, 08:30 PM
Need a bolt up exhaust system kit that comes with cat delete and clamps so I can unclamp the cat delete and clamp in the CAT for when I have to go get a smog test...
The previous owner of the truck had the stock cat cut out and a pipe welded in to fill the gap....=/ I bet you could see my face when I got the smog letter in the mail.
Thanks in advance.
Old 04-14-2010, 03:23 PM
bump?
Old 04-14-2010, 05:38 PM
Location: Savannah, Tenn. (over 100 miles east of Memphis)
Get you another cat to go on it, and hit up MBRP....they make a bolt in test pipe so you can change out your cat whenever you chose.
Old 04-14-2010, 05:45 PM
yah your going to have to buy another cat from someone and get a MBRP exhaust kit with the cat delete pipe and fit it in there
-Raul
Old 04-14-2010, 09:25 PM
So if I get a MBRP exhaust with their cat test pipe will a stock cat bolt up to those or am I gonna need reducer pipes or something?
There are so many MBRP kits...dont want to order the wrong parts...Can anyone help me out with some links? Looking for a 5" exhaust. I need it all clampable...dont want any welding..Would like to order ASAP. need to get the truck smogged.
Old 04-14-2010, 09:44 PM
yes the stock cat will bolt on... i can def get you a price.. did you want a aluminum or SS version? with a muffler or with a muffler delete pipe?
-Raul
Old 04-14-2010, 10:01 PM
Aluminum one hold up pretty well? Aluminum 5" , muffler delete, and 6" tip if you have it.
Old 04-14-2010, 10:14 PM
sent you a PM
