starveing for fuel - Ford Powerstroke Diesel Forum
post #1 of 33 Old 04-12-2010, 02:06 PM Thread Starter
starveing for fuel
I have a 07 with 225 injectors 66/71 turbo and supporting mods and i have the air dog fuel system all my work was done at river city diesel and when i run the truck wide open fuel presure will drop from 60 to 35.... i change the stock ford filters today and that did nothing. ive only had the setup for a month so i never changed the air dog filters. What do u think it could be??? thanks
outlawpowerstroke600hp is offline
post #2 of 33 Old 04-13-2010, 01:47 AM Thread Starter
river city diesel said i gotta put bigger lines on my transfer tank but i dont see why that would make a difference since the airdo is plumed right into the stock fuel tank
post #3 of 33 Old 04-13-2010, 05:27 AM
haters gonna hate 24/7.
blueovalman14's Avatar
do you have a regulated fuel system??
I've looked into all that n every place has said you need the ITP regulated return fuel system. it comes w/ a regulator that you can set your fuel presser at, i think......
Also, i was looking into a setup like that...... How much did you drop at RCD?? How do you like the setup so far??
2012 F-150 CC/SB 4x2 Lariat
2005 F-250 CC/LB 4x4 Lariat (Blue/Tan)- Traded In
2005 F-350 CC LB 4x4 Lariat (DSM/Tan) ---> RIP 7/16/2010 (Stolen)
1995 F-350 F-350 CC LB 4x4 XLT
Originally Posted by craftkr View Post
Maybe Choctaw will let you start the LSP Itty Bitty F1Fitty Daycare Chapter????
blueovalman14 is offline
post #4 of 33 Old 04-13-2010, 12:47 PM Thread Starter
yes i got the return. i spent 20,258 with them. the truck is awsome when it works.... ive had it a month now and the egt gauge went out. they put a faulty tourqe converter in it so i had to get that redone and now this with the fuel. and they keep buging me about my transfer tank and ik thats not it so they are of no help for getting it fixed so idk what to do
post #5 of 33 Old 04-13-2010, 02:33 PM
The Lady Mod
Granny's Avatar
Send a message via Yahoo to Granny
Did you plum into the STOCK pick-up tube? If so that is most likely your problem. The stock pick-up will not keep up with your 225s. I would keep my foot out of it, unless you want to burn up your injectors.
Granny aka Terri
04 F250 CC 6.0L PSD 2WD
A Few Ponies Under The Hood
Wrenches Turned by Trucks Unlimited (Thanks Scott!) and NPCCPARTSMAN
Injectors by Ryan Casserly of Full Force Diesel
Turbo by KC
Oil Cooler by BulletProof Diesel
SCT Custom Tuning
Granny is offline
post #6 of 33 Old 04-13-2010, 05:00 PM Thread Starter
well river city diesel did it...... you would think they would know where to put it??????? Where would i need to look to see if they did it right???
post #7 of 33 Old 04-14-2010, 03:53 AM
The Lady Mod
Granny's Avatar
What you need to find out is if they used the stock pick-up tube or not?
Granny aka Terri
Turbo by KC
SCT Custom Tuning
Granny is offline
post #8 of 33 Old 04-14-2010, 11:22 AM
There are a few aspects to this.
Are you running the AirDog as a standalone or lift pump?
I haven't seen a stand alone AirDog flow chart (not that I have seen them all) that could flow the required fuel volume at 60 psi to support anything larger than 215's.
Also, the entire system needs to be designed to flow what you need. Larger pick up tube, larger lines to the engine, larger lines on the engine. Your injector choice, is much larger than most, and some companies don’t always know what else needs to be done to accommodate the larger stuff.
hpprose is offline
post #9 of 33 Old 04-14-2010, 05:23 PM
npccpartsman's Avatar
Quoted: 5 Post(s)
1) Find out where and what kind of pickup tube your truck has. If it's the stock pickup it may not be enough to support 225's. Helmann performance makes a nice piece that bolts to the bottom of the fuel tank that has a LARGE port to plumb from.
2) You said you changed the ford FILTERS. If you're still running the OEM pump with an airdog lift pump then that may be the source of your problem. The OEM pump may not be able to provide the volume necessary. Just because you have plenty of pressure doesn't mean you have volume. Typically on most pumps they are rated to pump X gallons of fuel at a specific PSI. The higher the PSI the lower the volume.
3) Your truck does NOT have an injection pump like a tractor. Each injector is it's own individual pump. Your fuel pump supplies each injector with fuel. High pressure oil generates the necessary pressure to fire the injector.
4) It may be true that you need larger fuel lines from the tank to the fuel filter housing under the hood to accomodate your larger injectors.
5) Where is the fuel pressure reading coming from? The following is according to Ford: spec on econoline is 38-66. To test fuel pressure on a econoline its done at the back of the right head.
spec on f body is 45-73 To test fuel pressure on a Superduty it's done at the filter housing.
this is the updated spec and tests are done under load.
If your fuel pressure reading is coming from the return regulator then it may be perfectly acceptable. If it's coming from the fuel filter housing then obviously it's quite a bit low.
Without knowing exactly what they did to your fuel system it's really hard to diagnose your pressure drop. IF you are running an airdog2 stand alone pump then the pump comes with a 2 micron filter and you can remove the secondary fuel filter AND the black stand pipe that it fits on. If you don't remove the stand pipe it will shut off your fuel IIRC.
I Bleed Razorback Red
Ford Makes It, International Shakes It, Casserly Fuels It, KC Turbo Spools It, SCT Tunes It, and Trucks Unlimited keeps her Rockin the Road
npccpartsman is offline
post #10 of 33 Old 04-14-2010, 05:36 PM
back in the saddle
shu873's Avatar
Sounds like the OP is running one of RCD's advertised power combos. Not sure exactly what their "poor boy" fuel system consists of but I know it uses an AD 150 as a pusher to the stock HCFM. I would assume they put the larger pick up in the tank to feed the Airdog. There should also be a regulated return of some sort under the hood. Don't take this as gospel coming from me, but that's my understanding of it.
My advise to the OP would be to add a Raptor fuel pump to your fuel system. It is also made by pureflow tech, like the airdog. The AD 150 (provided you have the required fuel pickup tube installed) should provide plenty of gallon flow. I just think your stock fuel pump (HFCM) isn't keeping up with demand. If all else is good and done right, I think your stock HFCM is most likely your problem.
Kurt
'06 True Blue/Silver 250 crew cab
ARP's, EGR blocked
AFE stg.2, MBRP 4" pipe
Air Dog 150, ITP reg. return
Bulletproof oil bypass system
Banks technicooler
Ride rite air springs in the rear
EGT, boost, and fuel pressure gauges by DiProcol on the pillar
Plus a few other odds and ends...
shu873 is offline
