10K to spend on what?? - Ford Powerstroke Diesel Forum
Old 04-06-2010, 08:26 PM
To I decided to take out the lift and down size on the tires. And now im going to build up my truck for sled pulling but i still want to use it as my daily driver. I have a little over 10k that I can use to mod out the truck. What all should I get? Im a newbie when it comes to performance, right now i just have a 5 inch exhaust system. O yeah and its a 2005, ALL help would be helpful, thanks
Old 04-06-2010, 08:34 PM
Lt. Negativity
Head Studs 500.00
EGR Delete 500.00
Injectors 1600.00
Turbo 2000.00
Fuel System 400 to 800.00
Coolant Filtration 125.00
SCT 500.00
Labor on stud install 2500 to 3000
What else am I missing hmm
Studs, delete, head gaskets, rebuilt oil cooler, coolant filter, SCT, gauges, fuel system, traction bars. and you would have some left over.
Old 04-07-2010, 05:13 AM
Throw an upgraded tranny in it. Studs, EGR delete, Fuel System, injectors, turbo, traction bars. what class are you pulling in?
Old 04-07-2010, 07:15 AM
Hey thanks alot on the help. Keep telling me what you guys would do for setups...
Old 04-07-2010, 07:17 AM
8,000 pd diesel. it would be just for the county fair truck pulls
Old 04-07-2010, 07:27 AM
Traction bars, lockers, Custom tunes, guages, head studs, EGR delete. That should be good for a fun time at the fair. Dont forget the ratchet straps to crank down the front end.
Old 04-07-2010, 07:30 AM
a built trans is night and day pulling. Also the other guys have mentioned everything you could do.
Old 04-07-2010, 07:33 AM
Send a message via AIM to jhaddox
how many miles...if you could find a shop to do studs under warrenty that would be a big money saver...what mods do you have so far to it?...where are you located at?...
as for a list
Studs-400
205cc Injectors-Around 2000
VGT-HO or a 62/70 Fixed Geomerty turbo-Around 2000
EGR Delete-300ish
Airdog/Fass Low Pressure Fuel Pump-600
Reg Return-600
Tranny-Prices Vary (Suncoast, BTS, others)
SCT-500
Intercooler-Not needed but will help if you have the extra laying around
Elite Coolant Circulation Lines
Traction Bars
Depending on the exact pricing and if your doing the labor yourself of sending it out
Old 04-07-2010, 07:42 AM
I just turned 94 thousand miles on the truck and im located in northern Wisconsin. As far as mods right now i just have a 5 inch exhaust.
