Between a rock and a hard place
Hey guys,
I am really stuck here, i am currently talking to a ford esp rep at the moment and his price is 1875.00 for the 4yr/48,000 warrenty. My question is should i get the warrenty or purchase an oil bypass kit along with the sinsiter full egr delete? I would love to have arp studs put in, but low on cash to do that. I plan on keeping this truck for a good while and just want to avoid all the expensive repairs that these trucks can produce. I do run the Banks Six Gun with speedloader, but usually leave it on the 3rd power level 99% of the time. Will doing to egr delete eliminate the possibility of blown head gaskets? or should i just get the warrenty and be worry free for 4yrs and not modify it, or do the parts and see if it will almost bulletproof it? Thanks |
you possibly already voided your warranty by having a tuner on it. it would suck to buy the warranty only to have them void it by your tuner.
My dealer here is a mod friendly dealer and I have had the truck repaired with the tuner installed and they still covered it under warrenty. I am just not sure what to do, install the parts or get the warrenty?
Just my opinion, but I would save the money you would spend on the warranty, and put it towards the egr delete, head gaskets and studs and be done with it. I have not done this with my truck yet, but plan to by summer, it is starting to give me some symptoms that I may need to do all this sooner.
I don't know where you are at, but there is a shop here in Houston that will install the ARP Studs, new headgaskets, rebuild the oil cooler, and delete the egr for $2800. |
That is a good price for all that work tony. I am good friends with the senior diesel tech at the dealer here and he can do the work for me on his own time for around 2k. My worst worry is going out of warrenty and have some unforseen problem occur and not have the warrenty to fall back on. Man, why is everything so hard lol. After doing all the mods, what is my risk of failure vs just getting the warrenty and not touching anything?
It's kind of a crap shoot!! From what everyone on the forum says, as well as many other 6.0 owners I know, EGR Delete, Oil Cooler Rebuild, ARP Studs, headgaskets and an SCT Tuner and the motor is almost bulletproof!! The stock injectors are going to fail over time, they just do, so you may want to consider upgrading the injectors at this time as well. That can add quite a bit to the cost, but should not add too much additional labor if any. Just depends on who is doing the work. I can't advise you on which injectors are the best, as I really dont know, still doing some research on them.
Another common problem with the 6.0 is the FICM, as you have probably already heard, but there is a post on here on the re-solder procedure that several members have done themselves, seems to take care of the problem. I personally have not done any of the above yet, but like I said, I am planning on it soon. I debated on the extened warranty for a while as well, but got a copy of the contract and read all the fine print and decided for me it just was not worth it. Most of the problems I have had with my truck so far would not have been covered as they are normal wear items. Shocks, Wheel Hub / Bearing, Carrier Bearing, Ball Joint, Brake Caliper, Brake Pads and Rotors. The way I looked at the Warranty was this. I could spend 2k on the warranty, or for another $800 or $1000, I could make the truck as bulletproof as possible, and do a few mods at the same time!! My decision was also based on the fact that I manage a high performance shop, we dont work on diesels, but I know alot of people in the business, so I get parts pretty cheap, and if I can't do the repair in my shop, I make a few calls and can usually get a pretty good break on labor from another shop, if they even charge me labor at all. |
You're going to end up doing all of those mods anyway. Might as well do it now.
Either way, it's going to break if you don't have the warranty, and it won't if you do.
