what kind and size turbo???
im lookin to get a bigger turbo
but still run my stock injectors for now.what kind and size is good for what i got done to truck in my sig i tow a bobcat from time to time if that has anything to do with it . thanks |
elite diesel eng has 3 turbos for stock-tunned trucks that would really help you out.
Elite Diesel Engineering Torque Tow Turbo Kit for 6.0L Powerstroke Elite Diesel Engineering VGT-SR Turbo for 6.0L Powerstroke Elite Diesel Engineering Tow Power Turbo Kit for 6.0L Powerstroke both can be used with stock sticks |
i have stock sticks but runnin ID extreem street and race will those still work
Check this turbo out:
http://www.turbobygarrett.com/turbob...oke6LFlyer.pdf Shouldn't affect your chip. Might be able to write you a different one to work slightly better with the turbo but you'd be fine with the ones you have. |
Last edited by extremetraction; 03-31-2010 at 07:39 PM. Reason: Sorry. Forgot to post the link. |
Take that money you were going to spend and upgrade your injectors. As long as you have the fuel to support the injectors, that will be a much better deal for you. Being that you tow a bobcat occasionally, I probably wouldn't go over a 62mm compressor. So, you don't need big injectors. Something in the 155 to 175 range would be good for a 62. |
the first link I posted will flow better and give you an mpg increase. It is a small increase and it helps. Best thing to do is call them, you can get more info
thanks for your help
You're going to need a fuel pump if you plan on upgrading injectors... AD2 would be my vote. 155's and a 62mm would be a good combo if you're still planning on towing.
definetly upgrade your fuel system, if you go with bigger sticks you need to get more fuel to the motor (airdog, fass ect.)
