Which Intake system - Ford Powerstroke Diesel Forum
Old 03-23-2010, 10:40 PM
Send a message via Yahoo to jwindbigler
Which Intake system
Im sure that this has been posted before, but I am looking into buying an intake. After I buy a tuner, and the cat delete pipe for my truck of course. The only one that I have seen any numbers for is K&N, and they claim 15HP and I think it was 30TQ. I was trying to do some research on other companies, but didnt have any luck with performance numbers on it. I would like some help deciding which intake to get. Truck is an 03
Old 03-23-2010, 11:20 PM
Tennessee Powerstrokes
What year is your truck? The stock air box on the 6.0 is sufficent to support up to 500 hp. I personally would just do the zoodad mod which is making the openg larger where the intake pulls in air behind the grill. The filtration on the K&N is not up to snuff either. You will dust your turbo and be out a boat load of cash. Most of the guys i know run either the AFE Pro Guard 7 or a DIY tymar intake with a 4" piece of pipe and an open element napa filter. Do as you wish because it is your truck this is only my$.02
Old 03-24-2010, 07:06 AM
From what iv read you cant use DIY intakes/filters on 6.0's ^^^. K&N I heard is bad. I also remember reading fuel mileage isnt gained either?
Old 03-24-2010, 07:09 AM
This is correct, I misspoke
I also forgot to mention that if I was gonna do a CAI I would do a true CAI like Volant or S&B
Old 03-24-2010, 07:12 AM
I also just read where you are from. You will get busted good for removing emission control components and adding aftermaket mods in Cali! You should just as some of the guys who have gotten busted.
Old 03-24-2010, 08:37 AM
True, but my vehicle is registered in Michigan where there is no inspection required.
Anyway, dont go with KN because they cant filter ****.
Ive heard voolant and AFE pro-guard 7 so far
Old 03-24-2010, 08:49 AM
The stock intake is good up to @500hp. You shouldn't need anything other than that, and it's actually a good intake......
Old 03-24-2010, 01:02 PM
If you are going with an aftermarket intake, take a look at S&B. They have excellent flow and filtration numbers. The pricing is much lower than most others as well. here is a link with more info.
S&B 6.0L Ford
Old 03-24-2010, 02:34 PM
Thank you for the link
I wont be installing an intake for at least 6 months. I will stud the engine, and probably port and port match both the intake and exhaust ports to their respective manifolds, put a programmer on it, and a 5" exhaust before I do the intake.
Old 03-24-2010, 02:36 PM
Skip the intake and use that money on a full exhaust or gauges.
