I removed the EGR Valve outta my truck, and man was it dirty... But I was thinking about running a EGR VALVE DELETE/BLOCK OFF cause I cant afford a EGR Delete Kit till summer... Does anyone know where I can get a EGR VALVE BLOCK OFF???
What are you trying to block? The exhaust from going through the cooler? Or through the valve itself?
If exhaust through cooler: Some have put a "freeze" plug in the "y" of the up pipe. I've read the size for freeze plug is 1.375"
If through the valve: Turn engine off, let cool, and unplug the valve.
Unplugging valve will through a CEL on 05-07 not on 03-04.
I have an 04 and unplugged mine until mid April. Then I will delete the cooler.
i made my own egr cooler delet kit cost me about 20 bucks and some time. but you have to be able to weld and have a means of cutting some steel.
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
