6.0 intake gaskets with egr delete?
Are you guys that are doing the egr deletes also putting on new intake gaskets seeing as you at least have to lift up the intake to install the kit? I did order the turbo gasket kit. I have the RCD delete kit so full removal of the intake is not required, but i just want to have all the necessary parts on hand before the install.
the intake gaskets are a multi use gasket, no need to replace them, but if you want to, we have some.
Hey thanks for the input! I just wasn't sure if they should be replaced or not.
