FICM
I hace a 250 with rough starting unless I keep it plugged in. read many posts about a FICM. Can someone tell me what and where it is and what it does
Redd |
Sounds like a glow plug problem , not the FICM. Check the glow plug relay, glow plugs , as a last resort it might be the FICM
FICMFuel Injection control module. I just had the same issues, it wouldn't cold start unless it was plugged in. Dealer changed the FICM under warranty. There is a really good diagnostic PDF on another site. A quick search should find it. Keep in mind replacement FICM's do not contain software and must be programmed prior to use.
It is under the degas bottle (radatior overflow bottle) and a little further back. It is on the driver side valve cover. It is a silver box. Fo a search and you will find a test and fix proceendure
Here is where the FICM is located: Page 10: Component Locations |
Not all FICM's need to be programmed for them to work.
http://www.fordtechservice.dealercon...FICM_Guide.pdf This is the Tech guide that I referenced.
