sct help please!!! - Ford Powerstroke Diesel Forum
post #1 of 5 Old 03-16-2010, 04:17 PM Thread Starter
T Bone0416's Avatar
Cool sct help please!!!
ok so i have a 07 6.0 and a xcal2 online cheap so i bought the x street .street. and tow for it well i got the tunes went to put them on and the solfwear was bad so i send it to sct and thay send it back. today i put my new tunes on and the tow and street dont do anything it's like stock any ideas? the x street works but shifts hard and i'm scared to run it because i dont have head studs will i be ok running the X street? and what do yall thinks wrong with the other tunes?
T Bone0416 is offline
post #2 of 5 Old 03-16-2010, 04:40 PM
purplehorn1977's Avatar
the first thing i would do is get a set of gauges this will help in knowing when to get out of the skinny pedal. i ran my x street for almost a year until i started to get puking then it was time for the HG'S AND STUDS. there is no real answer here as all of these trucks are diffrent ive seen some that run tunes and never have problems and then ive sen alot of stock trucks that have hg's problems.
2004 F250 6.0 CC 4x4 SCT with custom tunes
zoodad mod, head studs, Home Brew EGR delete, 5" MBRP striaght exhaust, 05 headlight Conversion
HID Head and fogs.
Real courage is found, not in the willingness to risk death, but in the willingness to stand, alone if necessary, against the ignorant and disapproving herd. Jon Roland, 1976
purplehorn1977 is offline
post #3 of 5 Old 03-16-2010, 04:44 PM Thread Starter
T Bone0416's Avatar
i already have gauges what is the most egt and tranny i need to stop at ? i'm heard 1200 or 1300 from some ppl but i dont want to blow my heads
post #4 of 5 Old 03-16-2010, 05:53 PM
MoyockPowerstroke's Avatar
Get ahold of your tune writer and find out why the lower hp tunes aren't working. I would shoot for 1200*F max on EGTs and 200*F max on tranny...these are still slightly conservative, but safe.
'05 6.0L, 128k miles, Racor CCV6000 Filter, Oil Bypass Filter, Fumoto drain valves, Coolant Filter, ZooDad, HighIdleMod, BullyDog 4" TB, VXCF9 Strat, Edge Insight Gauge, Torque App, Fuel Press Gauge, Upfitters, 4" SJ lift w/Bilstein 5100's, Ride-Rite Airbags, Rough Country Dual Stabilizers, 24" Wipers, '08 Rear Diff cover, Mobil1 Syn 5W-40, 6.4L banjos, Blue Fuel Spring, SS HPOP screen, '08 Mirrors, Zerex ELC.
MoyockPowerstroke is offline
post #5 of 5 Old 03-16-2010, 06:11 PM
RIP Mitch ! We miss you
PGreenSVT's Avatar
Feedback Score: 3 reviews
1350 is the generally accepted EGT you want to stay below but exceeding that for a short time shouldn't be a major problem.
As far as what is safe for your heads/gaskets there is no way to tell. You have an 07 so it has all of the developmental improvements to the 6.0. I ran Xtreme street, or Looney or equivalent for 2 years before I had studs done. My head gaskets were on borrowed time when changed. I really wouldn't want to drive my truck with a stock tune all the time.
RIP Mitch
the Org crew
PGreenSVT is offline
