can you use aftermarket injectors with a WVO system?
Just curious...
An injector is an injector. Same rules apply as to the stock injector. Well filtered and heated to at least 160* before the injector.
Most will tell you over 200* is actually preferred. 160* is more of a base line, the hotter the better though (to a certain extent) 6.0's are a great motor to run WVO in because it gets heated in the head before being injected.
Larger injectors will be fine though. Like PGreenSVT said, it needs to be filtered well and heated to run. |
Yeah I was using 160 as a temp to turn the WVO on. By the time it gets to the injector it is nice and hot.
