temps?
Just wondering if anyone could provide the operating parameters for 05 f250for the following, egt's, boost, trans temp, rear end temp, oil pressure and any others would be greatly appreciated.
Subscribed. I've been wondering about a couple of these, too.
Ill try to help egts nothing over 1200 for a long time. Boost I have hit 34 before I wouldn't hold it for very long especially with stock head bolts tyranny I have never seen over 190 while pulling my camper I would say once you get around 210 you would be pushing it the other ones I don't no but would like to hope this helps.
I am at cruising speeds on the highway 65-70 as follows. Trans Temp 150-160* EOT 185* ECT 180* boost is about 5-10 psi depending on grade egt's are about 600-800* also depending on grade Rear end temp and oil pressure I don't know. |
subscribed
hey wild just out of pure curiosity what type and weight oil are you running?
On the numbers I posted.
This was after a new oil cooler was installed on Rotella 15W40. That was also on a road trip from NH to FLA and back. Consistent temps all the way down to GA-FLA then the oil and coolant temps went up to about 188* I usually run Motorcraft 15w40. |
also, i see my trans temps between 150-158 unloaded. While towing i'll see between 161-170. Have never seen trans get higher than 175* Last edited by FastFocus; 03-16-2010 at 09:15 AM. |
i see normal driving temps of
EOT 190-194* ECT 188-192* wild do you know why the temos went up? |
It was only a change of about 7-8* in EOT and ECT overall. I like to say suns out guns out. |
