Guys with MBRP exhaust please come in - Ford Powerstroke Diesel Forum
Old 03-10-2010, 12:10 PM
when i purchased my truck it had the exhaust on it. with just a quick look underneath i thought it was a 5" cat back with no cat. upon further looking and comparing it looks as if my down pipe is a stainless two peice unit that is 3.5". the mid pipe is also a 3.5" stainless peice. after that it opens up into what appeears to be a 5" galvanized tube, muffler and tailpipe. im trying to figure out if this is a kit or peiced together or what. here are few pics
downpipe and clamp, assumeing this isnt stock?
midpipe after down pipe, also 3.5"
galvanized tube muffler and tailpipe, definatley bigger than a 4" peice i had laying around
does anyone elses exhaust look like this or know what exacly i have? thanks
Old 03-10-2010, 12:55 PM
Most kits are either completely 304 or 409 stainless or completely galvanized with the exception being the tip. i dont believe kits come with a combination of both. I have a 4 inch kit with a 1 piece down pipe followed by mid pipe and then cat delete. it then goes into the extension pipe to the muffler and then out to the tailpipe. You appear to have a kit but have never seen one of two different materials. I think the end product, sound and performance is the same, just one looks better. Hope this helps
Old 03-10-2010, 01:54 PM
I have the MBRP 3.5 down 4 after that. I have the muffler and no cat. This is on a 6.0. I will try to take a pic but that last pic you have dose not look like what i have.
Old 03-10-2010, 02:02 PM
those arent the clamps my mbrp came with . . .they look like the clamps that came with my buddies silverline . . .
Old 03-10-2010, 02:06 PM
what im thinking is there was a catback first and then the down and mid was added later? im just seeing if all of my stuff is the same size and layout as guys who know the have a full 4" turbo back. i know they come with a 3.5" dp but i thought it would open up to 4" or 5" sooner than it does
Old 03-10-2010, 02:08 PM
the only reason i say mbrp is because that is whats stamped on the muffler
Old 03-10-2010, 02:13 PM
looks like you got some hillbilly engineering parts. if it sounds good I would rock it.
Old 03-10-2010, 02:24 PM
The front part looks just like my stosk exhaust did before I cut it off. I really think you have a cat back syatem that maybe someone added a cat delete pipe to later on.
Old 03-10-2010, 02:26 PM
Lets Spool UP!!!
x2 that looks exactly like my buddies silverline also front pipe is stock with cat delete
Old 03-10-2010, 05:31 PM
Send a message via AIM to wildfingas
Slowbra,
I think that could be what happened also. Cat back MBRP then went and added the DP and cat delete after the fact.
I have the MBRP Turbo Back off road kit and it opens up to 4" right after the DP.
