Head studs - Ford Powerstroke Diesel Forum
post #1 of 4 Old 03-08-2010, 10:24 PM Thread Starter
Head studs
Whats the deal with the head studs on the 6.0? are they warping and then blowing the head gasket? i have a 2005 with 37s and cold air and straight piped but no chip or tuner, should i be replacing these or letting them run? Ive only got 48k on it but not sure if i should wait or do it now. If so what would the average cost be?
Burk814 is offline
post #2 of 4 Old 03-09-2010, 01:30 AM
jwindbigler's Avatar
Send a message via Yahoo to jwindbigler
For the studs and gaskets - $675 in parts on ebay
6.0 Powerstroke F250/350/450/550 FORD Diesel ARP Studs : eBay Motors (item 200433142110 end time Mar-28-10 16:49:20 PDT)
The head bolts are rated only for what the OEM engine is rated for. However you can get away with an intake, exhaust and a tuner if you run the tune on a mild setting. Otherwise, the bolts will stretch and blow the gasket. I have heard that it can cost $2500 if you have a shop do it. But that is all hear-say. Hope this helps.
Please sign this petition to have the commercial vehicle fees removed from your yearly registration (CA residents only)
jwindbigler is offline
post #3 of 4 Old 03-09-2010, 04:33 PM
Joshs4x4toyz's Avatar
You can get arps and better gaskets from vendors on here cheaper than that....I suggest always givin the vendors on here a shot it never hurts to e-mail them for a price and CS is amazing compared to fleabay, these guys are on here and will help troubleshoot also....Give Adam a shout @ FCDP abrannan19@aol.com
Originally Posted by FX4STROKER View Post
mines named obama cause its not all black and makes me go broke
Joshs4x4toyz is offline
post #4 of 4 Old 03-09-2010, 07:33 PM
I will defiantly hit them up about the gaskets.
