is the dealer always gonna know ive got a tuner? - Ford Powerstroke Diesel Forum
Old 03-08-2010, 07:00 PM
i use an sct tuner. the last time i took the truck in for warranty work the tech called to question some issues & knew i had returned to stock , x amount of miles before. is there any way around this ? & how much do they know?
Old 03-08-2010, 07:05 PM
The only thing that comes up is a battery disconnect code (meaning it was just returned to stock.... or... you disconnected your batteries.) You can always return it to stock, then drive it around for a while, the code will clear on it's own.
I've never been denied work because of the tuner. I've also heard cycling the key 12 times erases it. I usually do that. Not sure if it actually works or not, but it couldn't hurt.
Old 03-09-2010, 05:30 AM
That's interesting, Mdub. Never heard about cycling the ignition before to clear the history. Will have to remember that one!
Old 03-09-2010, 06:28 AM
Yea that's what i did when i needed warranty work and i never had any issues.
Old 03-09-2010, 09:09 AM
Send a message via Yahoo to Lubbockguy1979
Probably shouldn't be upset if they do deny coverage if your tuned. It is pretty clear about tuning and warranty stand points....
