6.0 coolant filter - Ford Powerstroke Diesel Forum
post #1 of 54 Old 03-07-2010, 06:48 AM Thread Starter
If it aint a CAT itsa DOG
dieseldan2005's Avatar
6.0 coolant filter
I am considering getting a coolant filter kit for my truck. Which ones do you guys recommend? I have seen ones from dieselsite and dfuser. The one from dfuser says it uses plastic t fittings now and that kinda scares me on that one. Is there anyone else who has a good kit?
Diesel Dan
10,000 LAKES CHAPTER MEMBER
2003 F350 Crew cab long box, FX4, 6.0, torqshift, Lariat.
dieseldan2005 is offline
post #2 of 54 Old 03-07-2010, 07:34 AM Thread Starter
Diesel Dan
post #3 of 54 Old 03-07-2010, 08:35 AM
6.0DSLPWR's Avatar
I got the kit from dieselsite. It was a good kit and it came with everything you need. Probably could have saved a few dollars by piecing everything together locally but it was easier ordering the one from dieselsite. After all it is just a filter head, some fittings, and hose.
-Aaron
2005 Ford F350
SCT X3
Isspro Performax Gauges
Dieselsite Boots
Fumoto Oil Drain
Coolant Filter
MBRP Dual 4" Straight Pipe
Harley Headlights
Pioneer In Dash GPS
6000K HID Headlight and Foglights
Smoked Lights
6.0DSLPWR is offline
post #4 of 54 Old 03-07-2010, 08:44 AM
k2davis1's Avatar
I got dfuser's kit and I like it alot. It was alittle more $$ than dieselsites but I was told he uses better valves and also gives you 3 filters. The T's are plastic but I wouldnt worry about them they arent chintzy by any means.
2008 F-350 Crew Lariat FX4
6" RCX lift W/37" Falkan A/T
24" Fuel Hostage
5" Flo-Pro Straight
H&S Mini Maxx
S&B CAI
k2davis1 is offline
post #5 of 54 Old 03-07-2010, 11:31 AM Thread Starter
I wonder why they went to plastic t's? Just because of cost i would imagine.
Diesel Dan
post #6 of 54 Old 03-07-2010, 11:49 AM
blue06crew's Avatar
90% of all parts on vehicles are plastic anymore..i wouldnt be worried 1bit about the fittings..
2006 Ford F-250 4x4 Crew Cab
SCT- DJ's Looney
AIRDOG 2
6" Rough Country 4 Link Suspension
2" billet spacer/f350 rear block
AFE air intake
5" MBRP turbo back exhaust with 6" tip
Autometer Sport Comp Guages
38.5x14.5x17 Pro Comp Xtreme ALL Terrains
17x10 Diamo Black 17 Karat Wheels
RCD EGR delete
Custom Traction Bars
Recon Smoked Mirror Lights/Cab Lights
03 Turbo
to be installed:
Whatever i buy next...
blue06crew is offline
post #7 of 54 Old 03-07-2010, 11:53 AM Thread Starter
I have just seen some plastic parts fail that resulted in fluids leaking, so thats why i was a little leary. But if you guys are running them and they are holding up, then i guess they are ok.
Diesel Dan
post #8 of 54 Old 03-07-2010, 11:55 AM
no-tel-in's Avatar
This sure has been a hot topic lately... I pieced together my own kit on my 7.3 and a friends 6.0, have about $35-40 in each kit
2000 F-250 4x4 7.3
BTS Transmission - 6.0L Cooler
GTP38r
Full Fuel System with Return
2-Stage W/M & Nitrous
Adrenaline HPOP
238/100's
no-tel-in is offline
post #9 of 54 Old 03-07-2010, 11:56 AM Thread Starter
Where did you find your filter housing? Do you have a parts list?
Diesel Dan
post #10 of 54 Old 03-07-2010, 12:01 PM
no-tel-in's Avatar
don't have a parts list, but I got it all from napa, the filter is a 4070... And the base is application specific to a OTR CAT truck IIRC
2000 F-250 4x4 7.3
GTP38r
Adrenaline HPOP
238/100's
