EGT temps?
What are safe running EGT temps? I assume there is a standard safe range on the EGT's? truck is an 06 F350 DRW 6.0L.
1250 is what i've heard is a safe level, but i've also heard you can run it up to 1350-1400 just don't leave it there for very long
Dont hold it past 1300 for very long. I have seen 1700 and shes still living
Yea dont leave it past that very long. I have a couple times and only melted the abs wires on the passenger side cause it got so hot
but still runnin strong
So yu can drive around with it at 1250?
I'd drive to ford maint. shop if I saw 1250 all the time drivin around, prob best if it's kept around 1200 tops I would think normal 900 1000 1100 everyday driving
MINES set for alarm ,goes off at 1200 and get off the go petal JER-1 |
You can run 1250 for as long as you want with no issues other than a high fuel bill. Over that is iffy, there are a lot of factors involved with how long you can run it over 1250 without damaging anything.
I have buried my 1500 degree pyro numerous times though with no issues. |
Mine ranges from about 650 to 800 on normal driving with my extreme street tune
Yall have convinced me. I am going to set my alarm on my evo to go off at 1200 degrees, especially since I am now running SCT tunes.
rollin down the interstate i'm usually running 700-900*and when i get into it it runs around 1,100*... don't know if this helps you or not or if mine are even normal temps but hope ya figure it out
