Aftermarket Injectors
Hey Ya'll:
Pending a cylinder contribution test next week, I'm most likely gonna be looking at getting new injectors for my 6.0. I'm looking at getting a set of 155's so I can still use my stock turbo for now until i get a lil more money to upgrade that. With that being said, I was wanting to know which shops ya'll would recommend gettin them from?? What are some of the pros that you've seen with them?? (if your running a set) Thanks! |
i like my casserlys, but if i were you id go bigger than 155s. 190s and a stock turbo do just fine. my diesel mechanic has 190s and a stock turbo and it runs great.
but can you still tow heavy with 190's ?
you will do just fine with 155's, they will work great with the stock turbo and flow enough fuel to spool a larger turbo if you ever decide to get one. If you want some prices I would be more then happy to get you some.
Kenny, I hit the scales yesterday, I had a 30' 22.5k gooseneck loaded with a 07 F250 CC SWB 4X4 and my truck and it weight 23,400 lbs, my truck weighs 8950 with a full tank of gas and me in it, when on the scales I only had a 1/2 tank, so my load was around 14,500 I towed it in my race tune (not suggested) and my 190's with a stock turbo, still got 12mpg and EGT's were fine..BUT I have Casserly injectors, so other 190's will flow differently I suggest if towing, 175's or less, 155 is a great all around injector. |
What type of power numbers was he putting up w/ that setup, if ya know?? |
idk, it feels fast, high 400s im sure
Also, what brand injectors do you carry?? |
dang, that's pretty good for a stock turbo.
I'm assuming that he re-did the fuel system too?? if so, which system did he go with?? Also, who did the tuning on his truck?? |
Adam,
what were your egt like? And how do yu like the 190's with the stock turbo? |
If you go RCD, stick with a 175 or under, you will be very happy with them, the 190's from RCD are a lot of fuel for the stock turbo, 175's are ok, but the 155's are perfect. Everyone hears or see 155cc and they think, "oh the stock sticks are 135cc's so 155cc's isnt enough of an upgrade" which does sound right, BUT the stock injectors are rated to flow approx 135cc's, but the nozzle is only capable of flowing about 100cc's of fuel, and with the 155's the nozzle will flue a true 155cc's of fuel, so its a pretty big improvement over stock. If I had to buy new injectors today, I would probably go with 155's, just because ever set I have sold, the customers love them. Kenny, It really depends on throttle position, if I am easy on it its 1200 or so, but I can make it go as high as I want, I also have a aftermarket IC installed. These sticks work well with the stock turbo, but I will have a 62mm real soon. |
