Is it possible?????????? - Ford Powerstroke Diesel Forum
Old 02-25-2010, 10:16 AM
Is it possible to do studs one at a time if HGs have not been compromised and not actually pull the heads?
Old 02-25-2010, 10:34 AM
No.unless u pulled cab off
Old 02-25-2010, 10:38 AM
How much clearance do you need can you just raise it w/ jacks or does it need to come way up?
Old 02-25-2010, 10:56 AM
Way up heads have too go on straight down on studs.u can do it in cab but u have to pull head off then put studs in head in the back two holes then pit head in hold studs up with zip ties
Old 02-25-2010, 11:19 AM
It can be done with out pulling the cab. You have to move the engine one way in order to get one of them in.
