SRL 0-60mph times
Stock the truck went 7.89 seconds to 60.2mph
SRL tonight in the rain (very light rain) 4wd engaged boosted to 5psi it went 5.49 seconds at 60.3mph How does this rank with you guys using the edge insight monitor??? Just trying to judge it. Had a friend in the truck and he said he was held in the seat until I let up on it......... |
with canned tunes i did one at 5.12 seconds, extreme tune. i have the SRL but i havent done it yet. by the way i launch at 15+ pounds of boost.
If I got the boost up I think I could do better. Since it was raining and my tires are not the best I was sort of leery of going higher. I am amazed at the difference from stock to tuned.....I guess I should be putting away for hg as I am sure I will be needing them soon
Are you 4wd? And what cab style? 18" or 20" tires? Like I said earlier just trying to gauge my truck to someone elses, thanks |
Some where close to 5 flat is about right. The real amazing part is gonna be your 0-30, that is where these trucks flat get things done.
Go to track it holds all the true
I wonder what the 0-60 times would be on 35's. Also what kinda of EGT's are you seeing by the time you hit 60mph
I will look and see if I can find my timeslip from track. Had 35 with stock gears and stock tranny. Thinking. It was under 5. That was on a spartran tune ultra
how are yall getting your 60 mph time?
By looking at my speedo, it takes me about 8.5 seconds, and I hav an SCT with tunes.
I am not sure, but I think that you can do it right off your tuner! Plug it in while your truck is running and it will give you all kinds of options.
