Air Dog Pros And Cons!
Ok so i read up in the newest Diesel Power, that installing an Air Dog will not only help with fuel filtration, but with the obvious line pressure. What my question is what is the point where an Air Dog is needed to a guys list of mods? If i were to run stock injectors, stock turbo, Elites Insanity tune, studs and egr delete, would a Air Dog 100 be worth it or would i just be pissing my money away?
subscribe to this too. What is better airdog or fass?
Heard lot of bad things bout Fass...talk to Granny about Fass she has had nothing but problems with there pumps. I myself bought a Airdog 2 and installing it this spring...with the original airdog there is a problem when fuel gets down to a qurter tank and hey fixed it with the Dog2.....ok so pros for having Airdog is better filtration, cheaper filters, no air in fuel to damage injectors, acts as a helper to ur factory pump or with airdog2 it replaces factory fuel pump....as far as Cons well I really
can't come up with any. I bought mine for $599 from Performance Truck Products and they have excellent service and a vendor here! |
That good to know. Thats what i was planning on getting the airdog 2
Are you going with the airdog 100 or 150? at which point should you go with the 150?
Think i would just get the150 and call it done
I have heard of problems from fass, none about airdog.
Con: $500!!!!!! |
