Gear ratio question
Im wondering what for a gear ratio i should switch my 04 f350 to. im currently running 3:73s and 315/75/16 toyo mts and im putting on a set of 38/13/16 michelin xmls. the truck is a daily driver as well as i use it for work pulling cattle trailer with atleast 10-15000lbs loaded so i need this truck to be able to do this once i swap the tires. also the michelins are almost double the weight as they weigh 115lbs and the toyos are only around 70lbs. any input and advice is much appreciated
4.30s or 4.56
I am planning to go with 4.56's. As soon as I wear out my 35's I will be replacing them with 37's and all the research I have done only shows a 100 rpm difference between 4.30's and 4.56's. So I would recommend 4.56's with 38's especially if you plan to tow. I have also decided to get my setup from randys ring and pinon, they seem to be very knowledgeable and prices seem to be good also.
yah im leaning more towards the 4:56s to make sure i keep my power up im hopeing to find some from a wrecker and swap them or a good place on the internet that might swap.
