fuel pressure?
So I got my fuel pressure gauge and installed it but did not have the sensor hooked up for a while, so the gauge would peg out while driving. I just got the billet cap in the mail and installed it.
My problem is that the gauge only register's 50psi, Is this normal? When I really hammer it down it drops like 2psi. Did I ruin the gauge by having it pegged out for a while? Or is my fuel pump going out? Truck runs good and no chip on motor. any help would be great |
I dont know but heres a bump for ya id like to know what pressure they should run aswell
I think they should run 55ish psi. You may have thrown the gauge out of calibration by having it pegged, I had that happen when my EGT gauge went into the negatives due to a wiring problem.
You wont know until you try another gauge on it. |
thats kinda funny because I somehow got two gauges shipped in the mail to me. I was planning on selling one but maybe I will try the one that has not been hooked up yet to see if there is a difference. If there is I guess I won't be selling the gauge.
I would check it out for sure, then just send the other one back.
i'll give it a try tonight
Mine freaks out when there is air
How hard is it to install a fuel pressure gauge? What is good and bad as far as pressure readings go?
Per FORD, you should have a minimum of 45psi at WOT UNDER LOAD on a stock tuned truck. Most guys see around mid 50's at idle. If you are dropping significant pressure under load you have a problem, plugged filters, weak pump, etc... |
tried the different gauge last night, same 50psi.
Under hard load I only see a 2psi drop so around 48psi. Is there something wrong? Or is this a normal operation? Anyone else out there seeing this number on a none chipped truck? P.S. - I still have the Autometer Z-series fuel pressure gauge (0-100psi) sitting in the box, brand new only hooked up once last night to check the other gauge. Anyone wanna buy? |
