Turbo drain tube question
Which drain tube is suppose to be the better one? The 03-04 tube or the 05-07 tube? One of them is suppose to allow the oil to drain back out of the turbo better and faster. It was in an issue of Diesel Power but I can't find it. I'm replacing my turbo and I want to have the correct tube on hand when I reinstall the turbo. Thanks.
6C3Z-9T515-A. the inside diameter is larger to allow more flow
kidmogster is correct, its a solid drain tube, yours will have the flexible braided stainless lines.
Is the part # listed above for the 05-07 trucks?
I just recently changed my drain tube out, mine was an 04 and it was a solid drain tube, not steel braided. now the supply line to the turbo is braided. it should be soild, but like said above the 05+ is bigger in diameter.
Thanks for the help guys.
The braided line is the feed tube, the updated feed tube is solid, no fled, and the updated drain tube is larger. Can I get part numbers for both, or is there a kit part number with both and gaskets/o-rings?
Updated return tube part# 6C3Z-9T515-A
Do not know the part # of the oil feed line, but here is one on Ebay New Ford 9T516 PowerStroke 6.0L Turbo Line Super Duty : eBay Motors (item 160402490309 end time Feb-14-10 20:39:38 PST) I know the gaskets come in a new turbo hardware kit...kit is usually around $8 |
The part # for the hardware kit is 3C3Z-9T514-AD
