Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Performance Parts Discussion
Old 03-26-2006, 03:35 AM
lugnut lugnut is offline
hypertech power module
has anyone tried the hypertech power module for the 6.0? three levels of tuning adjustable on the fly and even at the highest setting[100hp.] they say its safe for towing. everyone is selling it for around five hundred dollars. jegs has it for three hundred fifty. i had good results with there programmer for my 5.7 chevy. thanks for any feedback
Old 03-27-2006, 11:17 PM
lilredpowerstroke lilredpowerstroke is offline
I think you might have the programmer and the Hyperpac confused. The Hyperpac is ajustable on the fly but is closer to 700 and the programmer is not ajustable on the fly and can be had for 399 or so. I have the programmer in my 7.3 and I love it.
Old 03-28-2006, 12:41 PM
no not the hyperpac. wish i could afford that. this is specifically for the 6.0 and its called the hypertech power module. it has a box that mounts under the hood and a knob that mounts in the cab. i ordered it and will let you all know what i think when i get it installed.
Old 03-28-2006, 12:57 PM
k_davis695 k_davis695 is offline
sorry i never tuned one of them but i am going to buy one and try it in the next day or two i will get back to you. I have a bully dog power pup stack on a edge attuide and it is making killer power. 800 ftlbs at the rear wheel but had to put in arp head studs!
later keith
p.s. will get back to u asap
Old 03-28-2006, 01:03 PM
thanks i appreciate it. when and if my gaskets blow i'm gonna do the studs. hoping i can just hand them to the dealer and have them put them in under warranty. i'll just make sure to take everything out and clear all the codes.
Old 03-28-2006, 10:57 PM
Only problem with that is when they take the heads off the tech will see a pretty flower or star pattern on the top of the pistons and know that you had it chipped (right Marc). And they are not gonna put the studs in under warranty, but you might be able to work something out once they say warranty denied.
Old 03-30-2006, 12:45 PM
Talking
well i just got back from testing out that hypertech power module. i can't judge it against anything but stock. in the lowest setting it wakes it up a little bit. second setting its pretty quick. third and highest setting its impressive. mileage was improving. barely touch the throttle and you are moving. fast. @20 mph i stood on it and it broke loose pretty good. ford limited slips suck. it definately feels like an extra 100 horse power. as i said i can't compare how it runs to anything but stock.
