Won't start and SCT X3 won't update - Ford Powerstroke Diesel Forum
Old 02-03-2010, 12:17 PM
So my truck has been running fine, then today (after I already ran it several times) decided it didn't want to start. I hooked my SCT X3 up to it and I couldn't change custom tunes, I could only revert it back to stock. So I did, and it still wouldn't start. Then I checked for codes, none. But it did start as long as my X3 was plugged in. Had to do the same thing this afternoon. Anyway, trying to update my firmware on my X3 and it went blank and I can't get the "find" the custom tunes through the browse button.
Pretty much I have no idea what to do and Innovative is closed for the week so any advice would be greatly appreciated. Thanks.
Old 02-03-2010, 12:28 PM
Old 02-03-2010, 12:49 PM
Anybody? I could really use some help.
Old 02-03-2010, 12:54 PM
Interesting. I would give SCT a call
Old 02-03-2010, 12:57 PM
I don't know nuttin....
Sounds like you PCM is fryed somehow? Definately call SCT tech line.
Old 02-03-2010, 01:39 PM
Yeah, hopefully you backed up your stock file...SCT will be able to rebuild you a working file from your back up that should load and get you back up and running. This is not something that Innovative could help you with anyway...get on the horn with SCT and you should be okay.
Old 02-03-2010, 04:33 PM
Thanks guys, it's working now.
Old 02-03-2010, 04:37 PM
Raging Lunatic
So, what changed????
Old 02-03-2010, 04:39 PM
Rob Rob is offline
what did you do to get it fixed??
Old 02-04-2010, 10:31 AM
x2...........
