I agree with KYmxracer above.
I recently had to replace my alternator because of a similar problem. My batteries got wiped out by the cold and the alternator just couldn;t keep up and it took out the voltage regulator. I would put the batteries on charge and have your alternator checked. And with all that, I would invest in an upgraded alternator.
DC Power Engineering Alternators check these out, Raul@Stealth Automotive (a member, and supporter here) is a great guy to deal with
Originally Posted by 05KeldermanKing
It also has amp power steps and a stereo system, along with two air compressors. The compressors fill up automatically every time the ignition is turned on. My question is, with all these accessories is there anything I can do to stop the batteries from gettin zapped every time I turn her on.
Do the compressors kick in as soon as you turn the key? regardless of whether the truck has started or not? If that is the case, I would put a switch inline on the compressors so you can wait until the truck is running before adding the draw of the compressors. The amp steps shouldn't draw too much and the stereo won't have an effect unless you let it play a long time before you try to start.
Also if I replace the batteries, what is the best brand?
I would recommend Optima yellow tops, personally, they are a little expensive but they are good batteries.
