Best Tow Tunes - Ford Powerstroke Diesel Forum
Old 01-31-2010, 05:37 PM
Best Tow Tunes
I am just starting to tow with my truck. Right now i am using cales 140 tune which is working good but i just bought a gooseneck and will be towing around 22,000 lbs on a regular basis. Who makes the best tow tune, i know that innovative makes and aggresive tow and cale makes a 100hp tow. Which one is better and what are the pros and cons.
Old 01-31-2010, 05:45 PM
say no to rolling coal
My honest advise is if you're going to pull that heavy then either run a transmission tune only (with EGR shut off) or stock tuning. That's a lot of weight for a 350. Do you already have headstuds and/or an EGR delete?
Old 01-31-2010, 05:46 PM
if your trucks a 94 f250......i wouldnt be towing 22k with it...... but i would go with a tw tune or a bts,swamps any of those guys are good.
Old 01-31-2010, 05:49 PM
I dont think he's talking anout a '94 mentioning the tunes he did, and mentioning Cale and Innovative, plus this the 6.0 section.
I agree with this. Also add in turbo braking
It is in the 6.0 section
He posted it in the 6.0 section...
Old 01-31-2010, 05:55 PM
Too cool for school
Feedback Score: 3 reviews
Send a message via AIM to taylorking Send a message via Yahoo to taylorking
Sounds like you need a Peterbilt or a KW
Old 01-31-2010, 05:56 PM
Hey Bud, Ya i got an 05 F-350 with a 6.0, I guess i should re word what i said. After doing some calculations i should gross around 24,000. I would defiantly get the turbo brake included.
Old 01-31-2010, 07:29 PM
I have cales 100hp tow with turbo brake and its flawless. The most I pull is a 10,000 lb trailer. His tunes are reasonable enough to try out, I don't know if I would try pulling that much with 100hp tow, but start light and see how the egts are.
Old 02-01-2010, 04:54 AM
Go stock or run a transmission tune. That much weight you shouldn't be running tuned. I have a 5th wheel that when loaded is about 18K and I was told by several tuners to not pull tuned....
