Pyrometer probe location? - Ford Powerstroke Diesel Forum
post #1 of 8 Old 01-29-2010, 06:46 PM Thread Starter
rescuemedic13's Avatar
Is it better to have the pyrometer probe located before or after the turbo? I have heard that pre turbo gives the most accurate exhaust gas temp. Also, what is a good brand of gauges and pillar pods.
rescuemedic13 is offline
post #2 of 8 Old 01-29-2010, 06:56 PM
back to business
07OUTLAW's Avatar
PRE turbo is the way to go.
ISSPRO for the gauges, IMO
Duane
2007 - F-250 Lariat OUTLAW
1983 - MERCEDES-BENZ 300D
07OUTLAW is offline
post #3 of 8 Old 01-30-2010, 03:01 AM
Pre turbo all the way...it really doesn't make much difference what the temps are after the turbo since the gasses going into the turbo is what can hurt it.
My pyro and a-pillar pod are both from Autometer...it's really more of a preference thing I think. Just decide what you think will look the best and want to look at when you are driving.
2005 F250 4x4 6.0L PSD, 6 Speed hand shaker
Dark Shadow Gray
SCT xCal2 with DJ's Tunes, MBRP Turbo-back Offroad exhaust...bye, bye kitty and muffler.
Finally studed, EGR deleted, blue spring, Zoodad and AFE CAI
Groundhawg is offline
post #4 of 8 Old 01-30-2010, 06:50 AM
Calkidd's Avatar
Quoted: 3 Post(s)
Egt Probe Placement ???
Calkidd is offline
post #5 of 8 Old 01-30-2010, 07:02 AM
Stoker0560's Avatar
mine didnt have instructions, well it basically said pick a spot and stick it..which didnt help much, i put mine just past the last port on the bend of the manifold just before it connects to the up-pipe, anything after that point and the exhaust only gets cooler so its a prime spot.. just be careful, the fitting is a pipe thread, tap too far and you'll run out of threads on your fitting,
another quick tip, put some grease on your tap so the metal filings stick to it and are not in your manifold,
09 F450 CC LB lariat 6.4 black on black 23k miles, stock.. (For now)...
97 F250 SC LB 4x4 7.3 05 Superduty axels, 18" King Ranch Rims, "under the knife"
Former 6.0 Owner. (05,05,03)
Stoker0560 is offline
post #6 of 8 Old 01-30-2010, 07:06 AM
Mob boss
Jarrod B's Avatar
Quoted: 149 Post(s)
always pre turbo. thats the hottest point that you want to monitor. getting it too hot can cause some issues with the parts on the engine.
i recommend ISSPRO gauges. they are decent and look great!
2006 Ford F250 CCSB FX4 6.0
Sold
1997 F350 CCLB 2WD 7.3
1999 F350 CCLB 4WD 7.3
2003 F350 CCLB FX4 6.0
LSP Chapter Director
LSP Group Threads
Jarrod B is offline
post #7 of 8 Old 02-03-2010, 09:49 AM
MichaelP's Avatar
Here is a brief write up on pre-turbo and post-turbo. And I always recommend ISSPRO gauges, but I'm a bit biased
Pre-turbo or Post-turbo thermocouple installation?
Clearly the manifold (pre-turbo) installation is better in almost all circumstances. Many people from the "old days" worry about thermocouple tips breaking off and chewing up the turbo. This fear is a relic from the days of exposed-junction thermocouples (the type still used in laboratories). For 40+ years the automotive standard has been to encase the thermocouple junction in a welded sheath of high-temperature stainless steel. More recently they have also been made out of Inconel stainless, which is rated for continuous use at 2000° F. Here at ISSPRO we have not had a single report of a sheathed-design thermocouple breaking and damaging a turbo, with over 40 years of history.
Measuring pre-turbo tells you more about the temperaures your pistons are seeing, as well as the worst case temperature of your turbo. The temperature difference between pre- and post-turbo can vary anywhere from +500° F (pre-turbo much higher when under heavy load and temps rising quickly) to -100° F (post-turbo hotter immediately after starting downhill after a hard pull uphill).
The only time we see post-turbo measurements as preferable is when monitoring the turbo temperature during shutdown. As the turbo cools off, it is being cooled by the exhaust gases at no-load (which are now cooler than the turbo). These gases get heated up as they cool off the turbo, so you actually see a warmer temp post-turbo. However, the difference between pre- and post-turbo temperatures is minimal by the time the turbo has cooled to around 300° F (which is where most people shut down). In other words, post turbo lets you see the cooldown progress better, but it is nearly identical to the pre-turbo reading by the time you reach the shutdown temperature.
Regards,
Michael Pliska
Engineering Manager
1995 F350 PSD CC DRW, 271k miles
10 ISSPRO Performax™ gauges, Tymar Intake, Gutted EBPV, Tymar 3x4" DP, Tymar 5" exhaust, Cat's lost, Baby Swamps, Swamps tuning, Tricumulator springs and Accumulator Valve, Tru-Cool 4590
1998 S&S 9.5' slide-in camper
33' enclosed tag trailer with 2 drag cars (73 Vega Super-Gas & 74 Vega ET)
92 GMC Typhoon, 73 Chevy Blazer with Pontiac 400, 73 T/A 455
GOA, IDPA & NRA member and certified firearms instructor
MichaelP is offline
post #8 of 8 Old 02-06-2010, 07:30 AM
Thats a nice little write up. I was always curious of the difference in EGT temps pre and post turbo.
brittonracing@yahoo.com is offline
