Stack Setups? - Ford Powerstroke Diesel Forum
Old 01-27-2010, 01:24 PM
Stack Setups?
what have you guys done to install your stacks? i was thinking bout puting in a 4 or 5 inch main/flex pipe from my stock downpipe into a 6inch tip? would it work or be too acward to do and just stick with a 4inch pipe through since i already have a 4inch straight pipe on it?
Old 01-27-2010, 01:59 PM
Are u just going for a single?
Old 01-27-2010, 02:08 PM
yep thats what iam lookin for.
Old 01-27-2010, 02:09 PM
a traditional bedkit for single stack or even dual stacks, will come with all your hardware to bolt up to any size of exhaust under your turck
Old 01-27-2010, 02:21 PM
does FTE make a good kit?
Old 01-27-2010, 02:26 PM
i've sold numersous people the single stack kit from FTE, i havent had a single person tell me they didn't like it
http://www.powerstroke.org/forum/fte...-179-95-a.html
Old 01-27-2010, 02:27 PM
so that kit will bolt onto my 3.5 downpipe? and be just bout in the same spot as that blue dodges stack is? you got any prices on it?
Old 01-27-2010, 02:30 PM
subscribing...
Old 01-27-2010, 02:37 PM
the kit will bolt up to whatever size of exhaust you are running under the truck, it will come with the reducers
the location of the stack will depend on where you want it, you can have it there, or you can ask for the "off-set" look and it will be moved about 3-4" to the passenger side
Price will depend on how bit of stack you want
if you want, just pm me with everything you want and i can get you a quote
Old 01-27-2010, 02:47 PM
pm sent your way.
