What signs are there of EGR problems? - Ford Powerstroke Diesel Forum
post #1 of 9 Old 01-24-2010, 04:58 PM Thread Starter
Power2336's Avatar
I have an 05 F-250 with 64,500K miles with no issues. I have been reading alot of the posts in here about upgrades, tunes, head studs and EGR probs and I am curious what are some signs that one may have EGR issues? Also if I dont have any problems and I decided to do the EGR delete on my own would it void any exteneded warranty threw FORD since this is a known problem with the 6.0 ltr?
Power2336 is offline
post #2 of 9 Old 01-24-2010, 06:37 PM
Send a message via Yahoo to cxrxaxz
Clean your egr vlave and install a coolant filter. As long as your not losing coolant and you keep your egr valve clean you should be ok for the most part.
cxrxaxz is offline
post #3 of 9 Old 01-24-2010, 09:33 PM
semmens21's Avatar
depends on the dealership but most likely yes it will void your warranty
SCT BY INNOVATIVE AND GEAR HEAD
4in turbo back farmboys diesel
zoodad mod
fog light mod
2.5in leveling kit
35in hankook dynapro m/t
Soon too come:
egr delete
head studs
Paint Job
semmens21 is offline
post #4 of 9 Old 01-27-2010, 09:47 AM Thread Starter
Power2336's Avatar
How would you go about cleaning your EGR valve?
post #5 of 9 Old 01-27-2010, 09:54 AM
remove the bolts pull straight up, if you are unable to remove the EGR valve after removing the bolts there is a egr valve tool you can you which will assist you. After that some carb cleaner and a brush will look brand new, removes the soot. Make sure when installing it is clean and dry. Thats it. I usually take it out and clean it ever time I do the fuel filters. 15k
2006 F250 King Ranch FX4
Cold air intake
MBPR Exhaust
06superpower is offline
post #6 of 9 Old 01-27-2010, 10:18 AM
Forgive this dumb question, but where is the EGR Valve located on my 2006 6.0?
byron53 is offline
post #7 of 9 Old 01-27-2010, 10:40 AM
It is to the left of the oil filter in the black casing. The EGR is the silver/black value cover with an electrical imput near the truck cab. It is held down by I believe two bolts
Cold air intake
MBPR Exhaust
post #8 of 9 Old 01-27-2010, 10:52 AM Thread Starter
Power2336's Avatar
do i need to disconnect the battery first and does it look like a small beer can? driver side or passenger?
post #9 of 9 Old 01-27-2010, 11:27 AM
DIVITA21's Avatar
Send a message via AIM to DIVITA21
Get a tune from Eric for your SCT and he can turn the EGR valve off. Did it on mine. Pretty easy fix with no wrench time.
JOE DIVITA
8.5 INCH LIFT
4 INCH MAGNA FLOW EXHAUST
SCT X3 WITH ERIC'S TUNES!
EXTREME STREET!
20 X 12 ROCKSTARS ON 37X13.50X20 NITTO GRAPPLERS
EGT AND TRANSMISSION GAUGE PILLARS
MAG TECH DEEP DISH TRANSMISSION PAN
DIVITA21 is offline
