3.5" verses 4" down pipe? - Ford Powerstroke Diesel Forum
post #1 of 19 Old 01-24-2010, 02:47 PM Thread Starter
Power2336's Avatar
I am looking into a MBRP 4" exhaust and curious what type of performance differences may be seen using a 4" verse a 3.5" down pipe? Not planning on hooking up a tune or serious engine mods as of yet.
Other then instal pains over the two is there a huge gain to be seen from one to other?
Power2336 is offline
post #2 of 19 Old 01-24-2010, 05:21 PM
SickStroke6.0's Avatar
Feedback Score: 9 reviews
Also interested. If I get a 4" downpipe with a full 4" exhaust, would there be any reason to upgrade to a 5"?
Blake
2013 F-150 CCSB Oxford White FX4 EcoBoost
Loaded with every option...
2008 F-250 CCSB Dark Copper King Ranch 6.4L FX4
4" MBRP Exhaust w/ Muffler (DPF/DOC Delete), Modded Stock Intake, H&S XRT Pro
SickStroke6.0 is offline
post #3 of 19 Old 01-25-2010, 03:30 AM
joe sinacola's Avatar
I have a 4" diamond eye down pipe now and before I had the mbrp 3.5" down pipe and I felt a slight decrease in torque with the bigger dp. If I could do it all over again I would have kept the 3.5 b/c there was more torque an it peaked louder than the 4". I hope this helps!
08 king ranch f-350
No Limit Fab, Flo-Pro dual 5"
arp head studs
all ford updates performed
bd 6.0 manifolds and up pipes
cooant filter, copper paint match mag hytec rear cover
external trans filter, deep trans pan
35/13.5 toyo r/t's 20x12 moto 962
recon leds, hids, led light bar
kenwood nav, bluetooth, reverse camera
remote starter
joe sinacola is offline
The Following User Says Thank You to joe sinacola For This Useful Post:
Kingvek (05-14-2014)
post #4 of 19 Old 01-25-2010, 05:51 AM
Crmsntide27's Avatar
Yea I have a straight through 4 inch and a ford tech was telling me that i would get more out of a 3.5 in downpipe because its provides slightly more back pressure which is good for your turbo.
Crmsntide27 is offline
post #5 of 19 Old 01-25-2010, 06:42 AM
FastFocus's Avatar
no offense, but that makes no sense. you do not need back pressure with a turbo. What you need is a smooth flowing exhaust, which depends on a few factors like the size of the turbo and how much boost your running, how much fuel, etc.
the turbo creates all the back pressure a gas and diesel motor will ever need. the exhaust after the turbo needs a smooth free flowing exit. The reason you may notice less torque with a 4" dp over a 3.5" dp is because with 3.5 the exhaust gas is flowing smooth and free flowing out of the turbo and out the tail pipe, thus causing more horsepower because the motor is not working to push the exhaust gasses out of the tail pipe. When going to a 4"dp you may run into the problem of having too much area for the exhaust to flow, therefore instead of the gasses flowing smoothly out the tail pipe they're getting bunched up and pushed out, therefore causing the lower tq.
an example would be, blow into a small coffee stirrer, then blow into a mcdonalds straw, and then blow into a straw that is 1" inner diameter. the mcdonalds straw is going to be the easiest to blow through and keep a constant steady flow. You cannot blow hard enough to do the same with the straw that is 1" ID.
However, a 4" DP will give a deeper exhaust note and will lower EGT's even lower. So take what you can get, its a trade off. a little more torque with slightly higher EGT's with a 3.5". Or a little less torque and slightly lower EGT's with a deeper tone.
-Aaron
'07 F-250 PowerStroke - 5" MBRP Straight Pipe, Edge Insight, Eric Tuned SCT, HID's, 2.5" Newton Lift w/ 4" rear block and Icon Caster Sleeves, Bilstein 5100's, 18" XD Monster's w/35" Toyo M/T.
'01 BMW ///M3 - Weekend Toy
'17 Chevy Malibu - DD and Company Vehicle
FastFocus is offline
The Following User Says Thank You to FastFocus For This Useful Post:
post #6 of 19 Old 01-25-2010, 06:46 AM
FastFocus's Avatar
if you still have your 3.5" DP you should put it back on and sell me the 4" .
-Aaron
post #7 of 19 Old 01-25-2010, 10:06 AM
The most bang for your buck comes with the removal of your cat.....engine runs smoother and cooler.
Not really a horsepower gainer, but worth 80 bucks.....engine seems to be much happier. I felt a very negligible difference in my buddy's truck w/ 4" exhaust but nonetheless a difference........
Stock 2005 F250
hewes18red is offline
post #8 of 19 Old 01-25-2010, 12:15 PM
smokersteve's Avatar
Quoted: 20 Post(s)
4" will be louder. 3.5" will have better performance. Some slight back pressure is good forthe VGT TURBO. This is not conserning the standard turbos. Some people notice the differenct some dont.
3.5" is better than the stock 3" dp.
13Q Trans Fluid Flush
FICM Testing Videos
smokersteve is offline
post #9 of 19 Old 01-25-2010, 01:35 PM
FastFocus's Avatar
not to hijack the thread, but whats the part # for the MBRP 4" dp? also, does anyone know the part # for the 4" cat delete? ive only got the 3" cat delete with stock piping right now, and want to go 4" dp, 4" cat delete, and 5" back.
thanks!!
-Aaron
post #10 of 19 Old 01-25-2010, 02:09 PM
5OH6.0's Avatar
Get rid of the stock muffler!!! its heavy and it is far more restrictive than the cat. MBRP in My sig fit precisely. Very happy w/same.
2006 F350 CC, SB, SRW, FX4, 3.5" Stainless MBRP Downpipe, 4" Stainless MBRP the rest of the way, Solid Up-Pipe FCDP EGR Delete, CCV Reroute,SCT X3 W/ID Tunes, Bulletproof oil cooler,Edge Insight Gauges, Fog Light Mod, High Idle Mod, Coolant Filter, SWAMPS FICM, No Cat,165k.
2002 F250 CC SB SRW 4X4 TS 6 Pos Edge gauges straight exhaust 6637 CCV Banks Big head Ranch Hand Bumpers 154k
In the end We will remember not the words of our Enemies, But only the silence of our friends.
5OH6.0 is offline
