Bought Edge Juce monitor but no attitude.....
Hey,
Got it off Amazon thinking that it was going to be usable when I got it. Only to find out that when I went to install it, the edge monitor is made to plug into the Attitude module under the hood. Only problem is I did not get it for some reason. I called Edge and he had me look at the date of manufacture, found out that it is from 07. Edge does not make these avalible separate any longer. So either I find the Attitude module all by it's self, or send it back and buy the Evolution system, which is what I wanted to start with... Fun fun fun So if anyone has a attitude for a 04 6.0 without the monitor I may be interested if you catch me before I send it back. PM if you got it |
I am guessing you bought it used of amazon.com?
If so, you are kind of out of luck, if you bought it new, send it back and get a refund, then buy a SCT. With that said, the Edge Juice should have a 3 position flip switch on the wiring, this will allow you to adjust to 3 different power levels, with the addition of the attitude, you get two more power levels and gauges. |
so do you have the monitor or the black box with a couple of connectors on it? the monitor is the attitude and the juice is the box that plugs in under the hood. i have one, monitor is fine but the actual box with the connectors that tunes the truck is fried. they wont work alone you have to have them together. so if you need the monitor let me know.
I have just the monitor, and yes I did buy it off Amazon.. but it was new. So waiting on a return authorisation code and going to send it back to em.
I am going to stay with the Edge though, I like the fact that it gives the same horsepower output as the SCT but it integrates the gauges.. saving me $$$$$! I am going with the Edge Evolution, because ease of install and the gauges. |
You would be a lot better off buying the SCT Livewire if you want the integrated gauges. I am a firm believer in SCT after the Banks six gun with speed loader messed up my tranny. Just my $.02, take it for what its worth. In the end though, its your truck and you have to drive it everyday-French |
ive had 2 buddys burn up there tranny with the edge. i dont know where you get your info about the same HP. the juice with attitude only puts out 110HP. My canned tunes will run off from an edge on a 6.0. thats just a canned tune not a custom tune. And if your buying new you can get a livewire brand new cheaper than a edge. maybe not cheaper than an evo, but remeber with a programmer(Note:I said programmer not tuner) your going to get what you pay for.
Answer this,
How is it that the engineers at Edge are making a programer that is so harmfull to a transmission? If it was so bad, one would think they would "change" the way the programer operates to match the hevenly SCT tuner....... What does the SCT tuner actually do for your tranny? I know the Edge does increase the pressure of the shift so it feels harder. But that's what I dont understand, how can SCT program differ much from a Edge as far as the tranny goes... Another thing, how many people have actually replaced a transmission that was attributed to the Edge? If it is a huge number, why isnt Edge footing the bill for these repairs? |
Thats like saying why doesnt marlbro pick up the tab on lung cancer treatments.
![]() Im no expert on all that but from what i do know, the edge will program you PCM and then jack the trans. line pressure up and thats it...... thats the way most programmers are made. Actually to correct myself, the edge only fools the PCM your not actually loading data onto the PCM. As far as the sct goes, when they tune the PCM it also changes all the trans. parameters. not just upping the line pressure. I dont know why you want to argue with experience? i mean its your truck, you have to drive it, do what you want. but if you want advice thats what people are trying to tell you. like i said though, its your truck, do what you want. As a matter of fact, go ahead and run the edge and give us updates every 5k miles. i promise they're wont be very many post. |
And as a matter of fact, they're are alot of programmer companys trying to go to a tuning device. just like super chip when you download it, it has a step you go thru that suppostly "tunes" the trans. i highly doubt it thou. they're shifting is horrible. I think quadzilla had "tunes" now too.
If you do a little research you would see the owner of SCT use to work for ford doing the calibrations. I also read somewhere he helped design one of fords trans. |
