6.0 Safe Towing Engine/Tranny/Turbo Parameters - Ford Powerstroke Diesel Forum
post #1 of 8 Old 01-18-2010, 12:49 PM Thread Starter
Now that I have my analog guages and edge insight I'm trying determine what is the safe operating range while towing this summer. I never run hotter than 1200 pre-turbo on my EGT's!
How much Boost is safe for a stock Turbo with 4" Exhaust? 30lbs?
What is the high end safe operating temperature for EOT? ECT? Tranny Temp?
04 Ford Black Harley Davidson Crew Cab SB, 5" Lift, 35" BFG KM's, Detroit LS Front, XDI Intake, 4" Turbo back Exhaust, EGR Delete, Coolant Filter, Edge Evolution, Edge Insight EOT, ECT, Tranny Temp, Analog Pyro & Boost, ATS Deep Tranny Pan & Diff Cover.
Bodi is offline
post #2 of 8 Old 01-18-2010, 01:02 PM
Snake's Avatar
Quoted: 46 Post(s)
First things first:
I see that your EGR is deleted....do you have headstuds?
Snake is offline
post #3 of 8 Old 01-18-2010, 01:06 PM Thread Starter
Correct. I dont have head studs yet. I tow with Edge Evolution on 100HP setting. I only use the truck for towing
Bodi is offline
post #4 of 8 Old 01-19-2010, 06:39 AM
Snake's Avatar
Quoted: 46 Post(s)
IMO, the first thing I'd do is get rid of the Edge and buy a SCT with custom programs. You'll make more power and it'll actually be safer. And you'll likely save your transmission.
Stock boost is around 22-25 lbs and bone stock trucks have blown head gaskets at these levels. If you're seeing 30 lbs of boost on head bolts, it's going to be a matter of time before your gaskets go.
I remember seeing some info about the effects of transmission temps on the fluid and its longevity, but I can't recall where it was. Unfortunately, I don't have the time right now to try to dig it up, but hopefully someone else will chime in with some answers.
Snake is offline
post #5 of 8 Old 01-19-2010, 06:45 AM
stroken04's Avatar
You mean these....
I agree with snake, Edge is pretty well known for destroying transmissions
stroken04 is offline
post #6 of 8 Old 01-19-2010, 07:08 AM
Snake's Avatar
Quoted: 46 Post(s)
Thanks Stoken! Those were the ones I was thinking about. You da man!
Snake is offline
post #7 of 8 Old 01-19-2010, 07:18 AM
stroken04's Avatar
No problem
here is the thread, they were in
TANK'S Library
post #8 of 8 Old 01-19-2010, 07:28 AM
FastFocus's Avatar
i've never seen my transmission get over 169* even while towing. I'm assuming this means the trans should hold together a LONG time i hope! .
Also, i did not change the fluid at 30k, but i did at 60k, and i will again at 90k. Fluid even though it was 30k overdue looked fine. The magnet in the pan was just covered which is expected.
-Aaron
'01 BMW ///M3 - New Toy
'07 F-250 PowerStroke - 5" MBRP Straight Pipe, Edge Insight, Eric Tuned SCT, HID's, 2.5" Newton Lift w/ 4" rear block and Icon Caster Sleeves, Bilstein 5100's, 18" XD Monster's w/35" Toyo M/T.
'17 Chevy Malibu - DD and Company Vehicle
FastFocus is offline
