EBP Sensors - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 11 Old 03-19-2017, 12:18 PM Thread Starter
shenanigans
junior125's Avatar
Quoted: 1574 Post(s)
Garage
EBP Sensors
Anyone know of a replacement EBP sensor that can go in the stock location that reads a higher set of pressures, or even what the threads on the factory sensor is and just put a T fitting there to add another sender/gauge
don't want to drill and tap these BD exhaust manifolds
Mike
2005 CCSB F250 4X4
junior125 is offline
post #2 of 11 Old 03-19-2017, 04:08 PM
Huge Mythical Beast!!
LoxDiesel's Avatar
Quoted: 369 Post(s)
What year.
Sent from my iPhone using Tapatalk
@loxdce
LoxDiesel is online now
post #3 of 11 Old 03-19-2017, 04:12 PM Thread Starter
shenanigans
junior125's Avatar
Garage
My 05, sensor is at the front of the valve cover
sent while slacking from something else
Mike
2005 CCSB F250 4X4
post #4 of 11 Old 03-19-2017, 04:27 PM
LoxDiesel's Avatar
Quoted: 369 Post(s)
Then it's 1/8" pipe thread. The later 05-07 are a JIC fitting. Your possibilities are endless
@loxdce
post #5 of 11 Old 03-19-2017, 04:29 PM Thread Starter
shenanigans
junior125's Avatar
Garage
Sweet, time to go find a T fitting then
Mike
2005 CCSB F250 4X4
post #6 of 11 Old 03-19-2017, 07:37 PM
TwinExcursions's Avatar
Quoted: 44 Post(s)
Garage
@junior125 why higher pressures need to be read. Just curious. Because of different turbo?
Sent from my SM-G930W8 using Tapatalk
05 Eddie Bauer
Blue spring/HPO updates/turbo oil pipes upgraded
EGR delete
IC to manifold pipe upgraded to steel pipe
58v FICM
SCT with Gearheads tunes
S&B stage 2 cold air
SD coolant bypass filter
Updated oil cooler
Edge Insight CTS2 c/w EGT sensor
ARP head studs
BD Diesel 7.3 fan clutch
4" Magna Flow stainless turbo back, cat empty shell
Heavy duty alternator (230A)
Buckstop bumper c/w Warn 16.5 winch
Warn Hubs, Eaton posi front/rear diffs
Toyo M55 285/75Rx16
Last edited by TwinExcursions; 03-19-2017 at 07:41 PM. Reason: mixed up @junior125
TwinExcursions is offline
post #7 of 11 Old 03-19-2017, 07:50 PM
RIP Cam!
Rattlesnake18's Avatar
Quoted: 954 Post(s)
Feedback Score: 6 reviews
Probably because he is running a non vgt...
2004 F250 CC Lariat 4x4
BPD FICM, BPD billet water pump, BPD VK688 oil cooler kit, S&B CAI, MTW stage 2, TSD tunes, Auto Meter gauges, Edge CTS, Sinister coolant filter, Blue spring, 6.4 banjo bolts, Straight piped w/ 6" single mitre stack, Pro Comp leveling kit, 05-07 HD headlights, Xenon-Vision 5k HIDs, Fumoto block drain valves, ELC, High idle mod
Originally Posted by djmaguire View Post
I'm guessing that you didn't lose nearly as much as it appeared. Spills are like that. The last beer that I spilled was like a million ounces.
Rattlesnake18 is offline
post #8 of 11 Old 03-19-2017, 11:53 PM Thread Starter
shenanigans
junior125's Avatar
Garage
Factory sensor falls off in the mid 40psi range
TwinExcursions likes this.
Mike
2005 CCSB F250 4X4
post #9 of 11 Old 03-20-2017, 05:41 AM
powerstrokecrzy's Avatar
Quoted: 250 Post(s)
Didn't Charlie do something to this effect. I thought i read he was, or at least trying to @peixinho
Sent from my SM-G930P using Tapatalk
05 250. Lariet. 4x4.
arp studs w/oem gaskets & all updates
Warren 175cc/stock sticks
Egr delete
Zoodad
New oil cooler
Coolant filter w/ zerex ec-1(homemade)
4" turbo back, straight piped
SCT livewire (running TSD SPD)
KC Turbos 1.5
Blue spring upgrade
riff raff boots
Ccv reroute (dump to atmosphere)
Air Horn Kit
high idle
Pro comp "bullet hole style" 17" w/ 35" nitto trail grapplers
powerstrokecrzy is offline
post #10 of 11 Old 03-20-2017, 05:51 AM Thread Starter
shenanigans
junior125's Avatar
Garage
Charlie tapped his manifold for it, I did rder the same gauge he uses
Mike
2005 CCSB F250 4X4
