Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Performance Parts Discussion
Old 10-30-2009, 04:58 PM
pdx_deisel pdx_deisel is offline
Need help..SCT w/ Edge Insight +Eric's Tunes
Hello,
My edge insight gauge shows N/A on some readings when custom tune is loaded. The readings shows as they should when returned to stock. I called SCT, they don't seem to know what's going on. Eric seem to think it's not his problem. I don't think it's the Insight b/c the reading are all ok on stock file. Anyone having similar issue? What's the fix? Thank You.
Old 10-30-2009, 10:13 PM
Calkidd Calkidd is offline
Very curious about this too since this is the setup I will be going with.
Old 10-31-2009, 12:31 AM
hazard hazard is offline
maybe try updating the insight to the latest software? shot in the dark but its something to try.
Old 10-31-2009, 06:22 AM
Abrannan19 Abrannan19 is offline
probably need to update the firmware on the insight as said above. Also what parameter is it not picking up?
Old 10-31-2009, 07:34 AM
Gamble Gamble is offline
Try going to SCT Automotive Performance Products click on tech support in the menu beneath the sct logo. Go to the bottom right and click on tech support videos. then choose "updating your x3 or livewire flash device". watch the video and do everything at the same time as they do. You will need to pause the video sometimes and you will have a couple of windows opened on the pc but it should guide you through all the stuff for updating. hope this helps, and good luck.
Old 10-31-2009, 08:02 AM
its not a SCT issue, its a insight issue.
Old 10-31-2009, 08:22 AM
onecrazyblackredenck onecrazyblackredenck is offline
Not trying to steal this thread, But how the hell do you update the edge?
Old 10-31-2009, 01:36 PM
My bad, semi paying attention....or rather, was semi asleep. I am waiting on my insight to show up so, hopefully this wont be a problem that I encounter also.
Old 10-31-2009, 10:07 PM
..Trans Temp., Boost, Deisel EOT and a few others...
Will try as suggested tomorrow...
Old 11-01-2009, 04:59 AM
InnovativeDiesel InnovativeDiesel is offline
Under the main paratemer selection screen, there are a few category's you can pick from under the menu selection. One category is Ford, the other is on the root of the menu, etc. Try picking each version of the parameter to see which one works, they will look in different locations for the data.
