- HOME
- FORUMS
- GARAGE
- ARTICLES
- CHAT
- CLASSIFIEDS
- VIDEOS
- TECH
- STORE
Road to the 650hp club
I have an 06 psd, I'm really wanting a streetable beast that I can put about 650 to 675 on fuel only. I want to run a 68 to maybe a 71mm turbo with 250 to 315cc injectors. Studs and egr delete coming soon. I'm wondering how my spool up will be, fuel system I should run, hpop upgrade?...etc. Any help would be great.
| Sponsored Links |
if you want streetable you can forget about either one of those injectors. i have 225s and they are too big for the street. if you want 600hp you can do 190cc injectors, stage 2 or 3 vgt turbo and nitrous, youll be around 600. it should have 500 with the turbo upgrade and 190s, then spray till you dial it in. yes youll need an aftermarket air intake, exhaust, head studs, egr delete, tuner and a fuel system to back this stuff up. good luck |
-French |
600 horsepower club: The basics: Intake (probably aFe stage II) Exhaust (strongly recommend 4” down pipe for that much horsepower, 3.5 will work) Sct Precautions: EGR delete Head Studs Bypass oil filtration system or Trusted Performance’s oil filter housing delete with dual oil filters (larger injectors add more soot, you need better filtration) Gauges, for this horsepower range, I would recommend: Boost, Backpressure (one for each turbo), EGT, HPOP, Fuel pressure and Oil Pressure The road to high horsepower: Complete fuel system (your choice, AirDog/Fass or non-regulated fuel pump like an Aeromotive both will work ok) Upgraded fuel lines Injectors, 205’s should land you in the 600’s 215 – 225 will land you very deep in the 600’s if you have the air Turbo, 66 or 68 is going to be pretty close with the right tuning, I believe you can lay down 600. Really, anything larger isn’t streetable. The chargers become very laggy and with injectors to fuel them, they are extremely smoky (not saying the 66 or 68 doesn’t fit in that category) Compounds would be the best way. You can keep your street manors and yet lay down huge horsepower numbers Intercooler, depending on which turbo(s) you choose, the intercooler will become suspect. Transmission, fully built with billet input shaft Torque converter, if you go with a single, you will need a high stall, something around 2300-2400, if you go with compounds, an 1800 stall will work just fine |
690 RWHP and 1398torque have been done with casserlly 200s, i think a .90 shot of nitrous and a hybrid VGT almost two years ago GoGoDiesel Forums - PSDPlayer's Album: Dyno Graphs - Picture |
Where and when are you going?
| Sponsored Links |
