Boost gauge hose - Ford Powerstroke Diesel Forum
Old 10-15-2009, 12:24 PM
Unapologetically American
Feedback Score: 4 reviews
Boost gauge hose
I noticed that I have a small hole in my hose about 8" from the port on the intake elbow. Can I just put a coupling in here, or do I have to replace the whole hose? I ask because of the heat under the hood, and my gauge pod clips are not reusable
Thanks
Old 10-15-2009, 12:26 PM
Shaking the Bush Boss
you should beable to use a coupler
Old 10-15-2009, 12:28 PM
You probably could a compression coupling to repair it. If I remember correctly I think its 1/8'' tubing. When I first ran my tubing it got melted by the turbo so I put wire loom around it and its been good since.
Old 10-15-2009, 12:31 PM
Thanks, anybody ever done that, use a coupler that is?
Old 10-15-2009, 12:35 PM
I haven't personally but It should work. When I tapped my banks elbow I used a compression fitting and it holds 35+ lbs of boost.
a truck
yep I have, had a kink in mine that ripped the hose so I put on a coupler and it works fine
Old 10-15-2009, 12:36 PM
Good point, sometimes my brain doesn't fire on all 5 cylinders . I'll take care of it this weekend
Old 10-15-2009, 12:39 PM
Heres what it should look like...https://www.hardwareworld.com/18-Bra...n-pRNHC1A.aspx Your local hardware store should have them.
Old 10-15-2009, 12:44 PM
Yeah, I knew what they were, thanks though Andy . I was worried about the heat, like an idiot
Old 10-16-2009, 06:27 AM
Send a message via Yahoo to Lubbockguy1979
They use the same fittings as I got from isspro in plumbing water and it can hold 80+psi. The weak link will be the tubing. I wouldn't hessitate to put a coupling in it. If you are concerned about looks then just splice it behind the firewall and run some new tubing to the intake elbow. Might try to ziptie it out of the way or protect it from the heat in the future though.
