egr cooler plugged w/ edge juice w/ attitude help - Ford Powerstroke Diesel Forum
Old 10-13-2009, 02:56 PM
hey i had a 6l at the shop, i installed arp head studs and i plugged up the egr cooler. i also installed a edge juice w/ attitude that i defiantly didnt recommend. i know there are much better programmers out there, but he is a paying customer and thats what he wanted?! now i know it would set a code, but i was wondering if anyone had any tricks up there sleeves to disable the erg valve from setting the codes. also on level 5 extreme, the egt's go soaring up to 13-1400 deg's. i know thats b/c of the egr cooler now being blocked off, and not cooling the egt's, but any help there would also be greatly appreciated.
thank you,
phil
Old 10-13-2009, 02:57 PM
i know that the sct tuner does clear the codes, but if there are any other remedies let me know. thanks
Old 10-13-2009, 02:58 PM
What year is this truck? and the high egts are because of the edge
Old 10-13-2009, 03:16 PM
i had the edge in my 7.3 it ran significantly hotter then with my tuner chip i think most of that is in the tunning sct would be the way to go
Old 10-13-2009, 03:25 PM
Keep it off of the higher tunes or you'll be replacing heads next time. always sell a package. a custom tune for an EGR delete which eliminates EGR function and safeguards against burning your work to the ground and having them return all pizzed off, lol
Old 10-13-2009, 03:26 PM
Plug the EGR in and zip tie it in the valley...
Old 10-13-2009, 05:12 PM
srry, its a 2006. oh and i replaced the heads (covered under esp warranty), but i got you. yea, i would of offered a package, but this was just going to be head gasket job that evolved into me doing this so...
Old 10-14-2009, 02:20 PM
bump........
Old 10-14-2009, 02:36 PM
Show him this page and tell him the Edge is junk. He needs the SCT on there to clear the codes, as far as I know its the only tuner available right now to do that.
