Tires. - Ford Powerstroke Diesel Forum
post #1 of 9 Old 10-12-2009, 10:41 AM Thread Starter
T.R.P.'s Avatar
Tires.
So I have a set of OEM rims and brand new 265/70/17's. When I put 2 of these on the rear end one time, and took the 35's off, the truck was ALOT quicker from 0-100.
My question, if I get an sct and have the 35's, does it tune the truck to run as good with large tires, as it would with smaller tires? Does it tune the transmission to run like I've got gears in the *** end?
Or would I still benefit from putting the smaller tires on the truck?
If you don't drink Dos XX's, you need to start today.
2007 F-250 Lariat FX4
SCT w/ Matt's SRL
37" Toyos on 18's
75,000 HARD miles and absolutely no problems. What's the deal Bill?
T.R.P. is offline
post #2 of 9 Old 10-12-2009, 10:50 AM
hypersnyper694788's Avatar
The bigger tires will always rob power. It wont run like there is gears in it unless you put some gears in it. But it will be more powerful so it should help. But all in all yes you will still benefit from putting smaller tires on the truck, as far as power and mpg goes.
06' F-250 CC SRW 4x4, 8" fabtech lift, bilstien 5100 shocks, 4" TB MBRP cat free, 2 JL audio 10" W0, 20x12 Weld Cheyenne 8, 35x13.50x20 Mickey Thompson Baja ATZ
BNIB oem ford complete 6.0 head, all valves hardware etc... for sale $900 obo NEW PRICE $600
hypersnyper694788 is offline
post #3 of 9 Old 10-12-2009, 10:50 AM
TampaSteve's Avatar
Feedback Score: 3 reviews
I think the SCT has a tire setting that can be changed......
TampaSteve is offline
post #4 of 9 Old 10-12-2009, 10:51 AM
Im pretty sure that is to set the speedo to be corrected for the larger tires.
post #5 of 9 Old 10-12-2009, 10:54 AM
01redcrew's Avatar
Quoted: 2 Post(s)
if you do a gear swap i believe you will have to change both front and rear gears at the same time
2013 6.7 with stuff
01redcrew is offline
post #6 of 9 Old 10-12-2009, 12:17 PM Thread Starter
T.R.P.'s Avatar
Well I know this, as well as the statement above, ofcourse to run like it has gears in it, you need to put gears in it.
What I am asking is, even with SCT custom tuning with tire size adjustment, will I still benefit at the track by putting the smaller tires on?
SCT w/ Matt's SRL
37" Toyos on 18's
T.R.P. is offline
post #7 of 9 Old 10-12-2009, 04:55 PM
i emailed eric a longtime ago when i got my tunes...the tire size option or rev per mile, is for the tunning of transmission, and it doesn't affect he speedo,odometer, or abs, just a things for shifting is what i was told, as far as benis at the track with smaller tires....i would assume so as long as your not making enough power to break all 4 loose right? your 0-60 and 100ft times wouldbe up but would hurt top end speed even then unless your going over 140 or so would prob be benificial....hope im right and hope this helps....just my 2c
tootall is offline
post #8 of 9 Old 10-12-2009, 05:00 PM
BigRed's Avatar
Correct, The SCT won't adjust your speedometer for tire size, the Revs/mile is all for transmission tuning and trying to get the shifts right. And yes tires ROB the hell out of power.
Waylon
2006 F-250 C/C LB FX4
SCT tuned by everyone!
ARP Studs
Elite EGR Delete
5" MBRP w/ 6" Tip
AirRaid Intake
AccuFab elbow
ZooDad
03 Turbo
6" Rize w/ 37/13.50R22 Toyo M/T's
22x12 Rockstars
AutoMeter Ultra-Lite EGT, Trans, Boost, and Air pressure gauges
Train Horns on ViAir 450C
Avic-D3 w/ 4-10's
BigRed is offline
post #9 of 9 Old 10-12-2009, 05:30 PM
Stoker0560's Avatar
As was said..Yes smaller tires will be faster on the strip..you will lose top end, but you will never hit top end on a 1/8 or even a 1/4 for that matter, the best set up is to acutally hit your top end, as you finish in the 1/4, but that would be silly for a truck you drive on the street.. You will gain at LEAST a few 10ths with smaller tires if not more.. I could tell a huge difference just driveing home from work when i went from stock tires to 35s...
And yes, if your going to put gears in it YOU WILL need to do fronts and rears together,, unless you want a quick and easy way to destroy your driveline. Just for the heck of it..make a few passes on your 35s and make a few on your 265s you'll be surprized!
09 F450 CC LB lariat 6.4 black on black 23k miles, stock.. (For now)...
97 F250 SC LB 4x4 7.3 05 Superduty axels, 18" King Ranch Rims, "under the knife"
Former 6.0 Owner. (05,05,03)
Stoker0560 is offline
