High idle mod on 03 6.0 - Ford Powerstroke Diesel Forum
Old 10-10-2009, 07:19 PM
loy loy is offline
How do I do the high idle mod on my 03 6.0?
Old 10-11-2009, 08:46 AM
you need to hook the blue wire with yellow stripe up to the white wire with blue stripe under your dash to a switch. The b with y stripe is up by your emergency brake sticking out with a tapped end. The w with b stripe is up by your OBD port and it to is sticking out with a tapped end. I tried it on mine and didnt work so I dont no what thats about. Ive tried everything and nothing.
Old 10-26-2009, 07:20 PM
did you put your e-brake on
