Safe to re-install SCT after FICM/FI replacement? - Ford Powerstroke Diesel Forum
Old 10-07-2009, 10:47 AM
Just spent butt load of money getting my FICM and #6 injector replaced. I have 12 mo 12k mile warranty on parts and labor. I wanted to get your opionions if I should ride stock for awhile, or if its safe to re-install my SCT.
I have the itch to put it back on, but curious to know if my SCT might of helped cause the failed FICM and injector. I know that the FICMs fail a lot on the 6.0, just want to make sure.
Im running Erics Xtreeme Street
Old 10-07-2009, 11:12 AM
Slacker
Feedback Score: 4 reviews
You should be fine. These FICM's go out on their own even without tuning.
Old 10-07-2009, 11:13 AM
letter buck! but its really up to you.
Old 10-07-2009, 11:14 AM
Put it back on. The sct has nothing to do with those two parts failing
Old 10-07-2009, 01:51 PM
how much was the ficm. mines in shop nowAND THINKING THATS whats wrong with it. but no ficm codes. did u have codes for the ficm? plus the ficm was new only a year old and out of warranty by 400 miles
Old 10-07-2009, 01:54 PM
Slacker
FICM goes and you will definitely have codes. Without codes, it is VERY likely you have a mechanical failure.
Old 10-07-2009, 02:14 PM
it said i had 4 bad injector on the same side
Old 10-07-2009, 03:50 PM
I paid $685 for a reman from dealer. I also had no codes, and never got a check engine light. Tech also found that #6 FI was bad. It gradually got worse from running like **** for the first 10 mins, to not able to even start. I tried pulling codes w my SCT, but never had one.
I spent around 900 for parts and about 900 for labor. I wish I new more about diesels
Old 10-07-2009, 05:50 PM
i had the diesel tech at ford pull the codes. thats what i was afraid of. thats what mine was doing but didnt let it get to the no start point. did the tech get a ficm code when he did it?
Old 10-07-2009, 07:25 PM
no he didnt get any codes either. I was running my SCT in tow mode at the time it wouldnt start, checked for codes....didnt have any. i then took it back to stock and tried to start it and it still wouldnt. this is when i had it towed to dealer.
If i could of pulled the codes, i prob would of saved a lot of money by researching on here and doing the fix myself....but since I had no clue what the prob was, I dished out my hard earned green
