Fluidampr
Is a Fluidampr harmonic dampner worth the money. Can you actually notice a difference? Thanks
Also curious
Hp gain probably isn't worth it, but if it makes your engine last longer would be worth it. Anybody have any experience. |
It made a noticeable difference for mine. I tow quite a bit and run stock for quite a bit of the time, but otherwise if you are looking to go fast, it is likely to break your LPOP gears.
You mean its not good if you put a lot of mods on your truck?
I know 3 people with mods that had one and they had issues as stated above....... I say no
From the research I've done and everything I've read on the fourms its OK on a stock truck, but the mod trucks have had issues with them, that they say were caused by the dampner. None were actually proven exactly, but they went back to stock dampner and issues disappeared. Search for it on here...
just say no, the money you will save can go to better mods that will work...
Agree, on a stock truck it would be fine, also reading alot being Im on 4 different forums the damper on a modified truck seems to cause problems later down the road. Just from what I read nothing 100%
i like mine alot, i have 190's etc,etc..motor idles noticeably smoother
