Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Performance Parts Discussion
  #11 (permalink)
Old 10-01-2009, 05:00 AM
extremlx extremlx is offline
I didn't think my truck had one so know what
  #12 (permalink)
Old 10-01-2009, 03:34 PM
THEPISTONHEAD THEPISTONHEAD is offline
Ah....good call. I wasnt paying attention. You can adjust with shims as you mentioned or call Dave Hoppert and tell him what you have. He will ask you to get an inclinometer or digital angle finder and take a few measurements. He can then possibly send you a rear traction block with a different angle. You may have worn u-joints.....too. There are a few possible issues.
  #13 (permalink)
Old 11-05-2009, 02:39 PM
well guys I solved the drive line problem with some help from Marty Garza at Truck Toyz. I told him what was going on and he told me it probably was a drive line angle issue so I put a call in to Tom Wood Driveshafts and he hooked me up with a double carden shaft and wa la, no shakes shimmies or vibrations relatively cheap to 524 to the door! I couldn't be happier with the traction blocks and the shaft. The taller blocks is what started the vibration, another inch and a half.
  #14 (permalink)
Old 11-05-2009, 03:11 PM
Vizsla Vizsla is offline
Woody shafts are the chit. I love mine, and like I said originally, sometimes it is the only solution. The lifetime warranty is nice also.
