NEXT MOD? - Ford Powerstroke Diesel Forum
Old 09-30-2009, 12:10 PM
NEXT MOD?
WHAT DO YOU GUYS THINK MY NEXT MOD SHOULD BE? I WAS THINKING REGULATED RETURN FUEL SYSTEM, OR FASS HPFP FUEL PUMP. JUST NOT SURE WHAT I NEED. WOULD SOMEDAY LIKE TO HAVE 190CC INJECTORS AND ELITE VGT-SS TURBO, BUT THAT IS WAY DOWN THE ROAD.
Old 09-30-2009, 12:30 PM
wriott
Guest
Posts: n/a
either one would be fine, but go with an airdog not a FASS system. have heard and seen alot of problems with the FASS systems
Old 09-30-2009, 12:33 PM
I WAS THINKING REGULATED RETURN WITH A PUSHER PUMP (FASS OR RAPTOR). OR DO I NEED AN AIRDOG OR FASS SYSTEM WITH THE REG. RETURN?
Old 09-30-2009, 01:02 PM
Lt. Negativity
If your gonna do the raptor pump you might want to get the airdog set-up. The RR would help with the dead head issue.
Old 09-30-2009, 01:13 PM
I don't know what I'm gonna do. I want a set-up similiar to RescueF250's. I guess a better question is what fuel mods do I need for 190cc injectors?
Old 09-30-2009, 04:08 PM
Why run a regulated return with a regulated pump? I was thinking about starting with a raptor and crossover at the rear and y a line off to a fuel press. gauge..if i need more fuel later i'll throw another raptor in line..i dont need 2 more fuel filters..the system is already set up with a return..maybe could use bigger line but...the truck calls for a certain amount of fuel..do whatever it takes to keep the heads fed and she should run!
Old 09-30-2009, 04:30 PM
i should clarify, i like the purpose of the airdog with its function.. to feed and remove air/vapor..but i really dont want 2 more fuel filters, it would be nice if you could at least bypass the large stock filter in the frame rail and run the 2 on the dog plus the stock one on the engine.. if thats the case im game on the airdog...and if needed down the road add another lift pump..
dont mean to hijack here, anyone had problems with jelin up in the winter, i push snow in the winter and if i could it wold be nice to simply shut off the airdog as its not needed when the truck is in "work mode" but its location ( or any aftermarket pump) isnt the greatest when plowing over drifts and running 65mph in -15 weather..
Old 09-30-2009, 04:37 PM
Don't have to worry to much about snow down here in Texas, but that's kinda why I wanted to keep the HFCM and add a lift pump because of the heater.
Old 09-30-2009, 04:54 PM
I guess thats my question too, is the HFCM not a good enough separator?
Old 09-30-2009, 05:04 PM
Lt. Negativity
The Airdog and Airdog 2 are different. The airdog 2 you have the possiblity to delete the frame mount one, also you can delete the fuel bowl up top. Some folks run the Airdog 1 and raptor pump straight to the front of the heads.
You can run the Airdog to the stock pump then to the front of the heads. There are different ways to do set-ups.
If he wasnt going to run an Airdog set-up, a regulated return is good for upgraded fuel system.
It is fine up to a certain point, when you start getting into injectors and fuel systems the stock HFCM wont give you a steady pressure of 55psi. Your pressure will drop with the demand of injectors.
