I know this is purely a matter of opinion, but I would like to know what others would do. I currently have the later style turbo and I'm looking at rebuilding it. I've read that the '03 style has a slightly larger compressor wheel as well as the larger 10 blade turbine wheel, which would allow this style to move more air than my current turbo. My question is would it be enough of an improvement to justify the extra couple hundred dollars to purchase a used '03? Either way I go I will rebuild with a billet single plane compressor wheel.
I knew the "it depends" is the overall answer, I'm just feeling out what others would do or looking for opinions from those who have done it. With the single plane billet wheel I was looking to see the '03 spool as quick as my current turbo in factory form. I pull my camper and boat more than I race, but I'm confident either turbo would do fine in those situations. The noise of the '03 isn't something I think I want. I've never ridden in a truck with one personally, but from the videos it seems like it would be obnoxious to me.
KC Turbo will sell you a new 2003 wheel for $200.00. I'm thinking about doing the same thing, my old truck must have had a 2003 turbo in it. My current truck sounds nothing like my last one ?
for my driving style the 03 turbo was worth $700 for a used one on my late build 04. plus the sound with a straight pipe is amazing!
I do enjoy my current 7.3l but i will forever miss the sound of a straight piped late build 04 with the 03 turbo... sounds like the c5s spinning up before take off.
The reason I ask.....if you ever want to upgrade injectors later or such, you'll be better set up to use the 03.....the 05+ turbos just can't support it with their smaller size. Up to a Stage 2 turbo can be safely built out of an 03 with no machining required, just drop in parts.
Like Jeff said the trade off is spool time. The 05s spool quicker off the line, a Stage 1.5 based 05 even more ridiculously so, but it chokes out above 3000 RPM and when I had mine I could feel where the turbo was being pushed out of it's efficiency islands as RPMs didn't climb as fast and EGTs climbed higher. The 03 turbo will take another 200-300 RPM to spool up, which if you have a lighter foot I honestly doubt you'll ever notice, but if you have a heavy foot, you'll feel a little lag until the turbo catches up, and maybe a little smoke if you run a hot tune.
And then there is the "benefit" (depending on your opinion) on the whistle; some people like it, some don't.
If you don't really race and go WOT most of the time and your primary use is as a DD and towing rig, I think you'd be better off to save on the 03 and get a Stage 1.5 kit and get the bigger compressor on the 05 turbine. That was an amazing little turbo but I like to go too fast and needed something a little bigger...
I really don't want the whistle, but I will take it if it's a better choice. I like the idea of the KC 1.5 a lot, but it's a little more expensive so it didn't make this discussion. I don't really have a goal for the truck, just fun to drive and can pull my boat and camper around no problem. I will eventually upgrade to 155/30 injectors. I will jump on the throttle from time to time, but I won't be entering pulling competitions or shooting for a specific time at the drag strip.
Damn Jeffrey.. Back at it again with the white ford haha
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
