sct and speedometer - Ford Powerstroke Diesel Forum
post #1 of 7 Old 09-23-2009, 09:45 AM Thread Starter
sct and speedometer
does changing the revs per mile on my sct correct my speedo reading? just went from 265/65/17's to 275/65/20's and really like it.
chaseon is offline
post #2 of 7 Old 09-23-2009, 09:48 AM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
No it cant. Ford can. Or you can get a superlift truspeed.
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #3 of 7 Old 09-23-2009, 09:55 AM
semmens21's Avatar
not to hi jack the thread but if ford changes your speedo will it change your strategy
SCT BY INNOVATIVE AND GEAR HEAD
4in turbo back farmboys diesel
zoodad mod
fog light mod
2.5in leveling kit
35in hankook dynapro m/t
Soon too come:
egr delete
head studs
Paint Job
semmens21 is offline
post #4 of 7 Old 09-23-2009, 09:56 AM
Goose350's Avatar
The revs per mile only change the shifting. I wouldn't think Ford calibrating the speedo would change your strategy
The Mullet Mod
Stock 2005 F-350 4x4
*Afe Intake
*4" TB Exhaust
*Scangauge
*SCT
oil bypass
water pump
*Tuned FICM
Goose350 is offline
post #5 of 7 Old 09-23-2009, 10:23 AM
Lubbockguy1979's Avatar
Quoted: 5 Post(s)
Send a message via Yahoo to Lubbockguy1979
It depends reguarding the strategy... If you have the most recent flash theb you should be fine. Ford cannot calibrate the speedo for anything larger than 34" tires if you have a 3.73 rear diff. I just went thru that. The options are either a mod box like the truespeed or auto enginiuity which is a code scanner that is capible of programming the abs sensor. Not sure what your new tires are size wise but my 315's on 16 inch rims are 35" and my spedo is set as close as they can at 65 on the spedo I'm going 70
Randy
2006 f250 4x4
crewcab shortbed
lariat auto
Some tuning, gauges and other assorted non factory dodads
Lubbockguy1979 is offline
post #6 of 7 Old 09-23-2009, 02:51 PM
semmens21's Avatar
mine are 35s on 18s so will i have to get a true speed through raul or what would you suggest?
zoodad mod
fog light mod
2.5in leveling kit
Soon too come:
egr delete
head studs
Paint Job
post #7 of 7 Old 09-23-2009, 03:11 PM
Quoted: 5 Post(s)
If you go truspeed it will only serve one function. If you get the auto enginuity it can work as a comprehensive code scanner and scantool for the 6.0 as well as other vehicles. It would really come down to how much each will cost and how you would use it to make the total cost effective. The auto enginuity would have to have the ford liscensing which is at an extra cost. It would probably be cheaper for the tru speed but the ae would do a lot more if you plan to ever work or diagnose problems on your truck.
Randy
2006 f250 4x4
crewcab shortbed
lariat auto
