EGR delete - whats needed - Ford Powerstroke Diesel Forum
Old 09-22-2009, 08:32 AM
Own an 04' 6.0L and what to know what gaskets or any misc. items. I've been told the intake gaskets are reusable, is that true?
Buying the turbo drain o-rings.
Buying the updated turbo drain tube.
not buying intake gaskets.
What do I need to do to my oil cooler while I am in there?
Anything else that needs to be addressed while having the intake manifold off?
Thanks for the help.
Old 09-22-2009, 05:13 PM
I'm in the middle of doing an EGR delete on my 04. I picked up new intake manifold gaskets just to be safe and also got an oil cooler rebuild kit off of Ebay and the updated oil cooler drain tube. That's everything I am addressing.
Make sure you have a good tool set and several socket extensions to get the up pipe bolts off, that thing is a *****. I'm sure it won't be fun putting the new one on either.
I cleaned my turbo since I had it off, I was surprised how much crap had built up on the vanes and ring in only 70K. I'm sure there are a lot of guys here who can do this project pretty quickly but since my truck isn't a daily driver I'm taking my time on it.
Old 09-23-2009, 04:10 AM
how much was the oil cooler rebuild kit?
Do you think an impact would be a good idea on those up-pipe bolts?
Old 09-23-2009, 04:56 AM
I didn't need an impact wrench. I sprayed them with some PB Blaster and they broke free. Whats hard is since it's a bolt/nut you have to hold both ends so it doesn't spin while you try to unscrew it.
I found the oil cooler rebuild kit for $200. Part #3C3Z6A642CA There are a few on Ebay now.
the uppipes are a pita to get at and get off. especially the y pipe off the turbo. the flange likes to hang on real tight.
spray some pb blaster if you can reach it like a day before and you shouldnt have too much of a problem.
if you take the passenger side wheel well out it gives you tons of room back there. I used an impact with alot of extensions and was able to get it out. it helps having someone up top holding the bolt was spinning
Old 09-23-2009, 07:04 AM
thanks for the help guys, does anyone know the part number for the turbo oil gaskets?
Old 09-29-2009, 10:03 AM
Here is my parts list-
Intake manifold gaskets PN 3C3Z-9433-AA (Reusable possibly return).
Turbo Oil Drain Upgrade PN 6C3Z-9T515-A (kit)
Oil cooler rebuild kit PN 3C3Z-6A642-CA
Oil feed tube gasket PN 3C3Z-6B898-AA
Inlet Pipe Gasket (2 required) PN 3C3Z-6N640-AA
Total for all parts 337.45 US Dollars
Is there anything I should know about this oil cooler rebuild kit?
Old 09-29-2009, 04:47 PM
The oil cooler rebuild is very easy and the kit should come with instructions. You simply sway the new cooler and o-rings into the top/cover of the old one.
