6.0 low idle
Quick question not sure if its possible. I know you can set the cummins on low idle, is there any way to set the 6.0 on low idle.
how much lower you want to do. its like 600ish as it is
Its higher than that. I never messed with it so im not sure what its at. I wanted to set it lower cause it sounds bad ***. Im not sure how to change it though
are you saying yours doesn't idle at 600ish
you want your idle to loop? just because you like the sound? right...get a programmer and ask for a loop tune or something or have them turn the idle down i guess |
You can set the idle rpm with a x3 but idk if you can go lower than stock
Yea i want it to loop
Is there anyway to make it lope idle without a tuner
Your talking about the Lope Idle tune.
Yea but i wasnt sure if you definately needed a chip to make it lope idle
Ya it would be custom tuning.
